Forum: µC & Digital Electronics Siemens S65 - LS020 Display MAximum SPI Speed
Author: Sobak Ava (Guest)
I'm using this display with a LPC2148 ARM7 CPU. Documents on the net
says S65 mobile phone drives this display at 13MHz SPI clock speed but
if I use speed about 3.75MHz it does not work.
Is there anyone has used display before at faster speeds?
I've no series resistors between MCU and LCD. MCU works @ 3.3V.
I did not connect 1.8V input of the LCD to anywhere. It is floating
because I saw some documents say it is not functioning for LS020.
I connected 2.9V input to 3.3V supply.
And my cable is around 10" ( 25cm ) long. Is is a problem?
Regards
I made a mistake.
Please note, my LCD is already running fine with 3.75MHz or lower
speeds. I want to make it much faster.
Author: Philipp (Guest)
I've run the LCD at 4MHz without trouble, even with 3k3-Resistors in the
clock and data wires. But my system runs at 3V and all the display
supply pins (including 1V8) are connected to this voltage.
Philipp
Author: Joachim (Guest)
Yes!
Probably not with about 3 MHz, but definitely with >10MHz.
The display should work with 12 MHz because in the original mobile
application, it runs at about 12.5 MHz.
Joachim
Author: gunni (Guest)
I run my lcd with 8 MHz and a very short cable.
MCU (Atmega32 Clock 16 MHz) runs with 3,3V.
i want to try it faster with an ARM7.
Youtube-Video "Atmega32 öffnet BMP von SD/MMC und zeigt es auf S65 Display"
Author: shiramoo (Guest)
I am running on S65 to 10MHz SPI using a PIC24H and no problem up to now
using a 10cm cable.
Author: Zippi (Guest)
I use it in High speed ;).
48Mhz spi (1.8V not connect) 3.0V on power line. Works good. I have no
problems.
wow amazing spi performance Zippi  . Please tell me which micro do you
use ?
My PIC24H is limited to 10MHz.
I Use the AVR32 AT32UC3A Microcontroller. The AVR32 can use spi_clk =
main_clk, for high speed SPI.
AVR32 max clk is 66 Mhz. overclock(96Mhz).
Author: Lupin (Guest)
I used the LS020 with 48 MHz too, everything above 48 MHz wouldn't want
to work any more.
With 48 MHz the interface is fast enough for fullscreen animations and
such.
More than 48 Mhz also not work on my board.
I have with 48Mhz and a very simple fullscreen animation more than
140fps ;).
oh sorry i mean over 120fps in DMA mode.
