Posted on: 2009-05-05 14:45
Hi
I needed to create a simple delay subroutine by using dummy loops. I
found some calculations and tested/working codes for LPC2148 on the net.
Three of them are:
Code:
void delay_ms(long int ms)
long int i, j;
for(i=0;i for(j=0;j<6553;j++);
OR
Code:
void delay_ms(unsigned long int count1)
unsigned int i,k;
k=count1*2600;
for(i=0;i<k;i++); // Loop Decrease Counter
OR
Code:
void delay_ms(int x) //this isn't accurate right
now{ //it's just a rough delay int a,b;
for(a=0;a<x;a++){ for(b=0;b<3000;b++); }}
Well, these supposed to be work but they do not.
I do something like this:
Code:
while (1) {
IOSET1 = 0x01000000; // turn off LED
delay_ms(10);
IOCLR1 = 0x01000000; // turn off LED
delay_ms(10);
I already made port direction settings etc.before this piece of code. It
is working correctly. But delay_ms() seems not become compiled because I
see very short (around 300-500 ns) pulses using an oscilloscope.
I tried to use delay_ms( 10000) insead of delay_ms(10)... Nothing
changed.
Then I tried to increase i and j end values in delay_ms() function.
Nothing changed.
for instance
Instead of for(i=0;i for(j=0;j<6553;j++);
I tried for(i=0;i for(j=0;j<16553;j++);
pulse durations did not changed. The stranger thing is, I compared two
hex files byte by byte and they are identical! so 6553 to 16553 does not
change anything in code.
Then I thought may be the compiler does not compile dummy loops because
of optimization, I added some arithmetic calculations in loop:
Code:
for(i=0;i for(j=0;j<6553;j++) a++;
nothing changed. It seems loops are not compiled. ?
I thought may be there is another delay_ms function in the search path
include files. I changed the name to my_delay_ms... Nothing changed.
Finally I did something like this:
Code:
long int i, j;
for(i=0;i for(j=0;j<6553;j++) {
IOSET1 = 0x00000001; // set P1.1... it is an unused pin. just
for testing
after this delay_ms has effect (delay). Why It does not work and it has
no effect if I do not place a port operation inside the loop?
Posted on: 2009-05-05 14:53
that looks like optimization. your loops and the used variables were incremented only but never used for read access. put your variable a as volatile and for(i=0;i for(j=0;j<6553;j++) a++; shall work. Better would be use of a timer and compare that content with your delay time. You will never know what your compiler does or if the sequnece is cached (ARM7) and takes less time. JL
Posted on: 2009-05-05 21:35
Make i volatile. Interesting observation: Some compilers (e.g. RealView) don't seem to optimize empty loops "for (i=LIMIT; i>=0; i--);" even at high optimization levels. I suppose that the assumption is that empty loops are there for a reason. Regards Marcus http://www.doulos.com/arm/
Posted on: 2009-05-06 21:18
It is not strange behaviour. It is exactly expected behaviour. For an explanation read this article: http://www.embedded.com/columns/beginerscorner/9900209 However and empty loop is a really dumb solution to delay timing. The chip has several hardware timers that won't vary between compiler or optimisation settings, I suggest that you use one of them. Moreover wrap the hardware access in a function (preferably in a separate hardware abstraction module), so that porting the code to a different device, or one running at a different clock rate or clock configuration only requires changing one function. Note that if you poll a hardware timer, or a counter updated in an ISR from a timer interrupt, that variable or register must too be declared volatile. The register header you are using should already declare device registers volatile. Clifford
