Hello everyone, I am new using LPC2148 and WINARM tools. Before this i worked with IAR and TI microcontrolers. So i have a MP3 DEVELOPMENT BOARD of SPARKFUN and i get the free SW that SPARKFUN has in its web. I have read that this SW is for WINARM. This programming enviroment is new for me and i am in a mess. So i would like someone could answer me several question i have. It would be great. 1.- WINARM is only for programming through programmers notepad. But it is only to programming, not to debug. I need to debug throuhg a JTAG to check my program and to find out several mistakes. The question is that I DON'T KNOW HOW TO DO THIS. ¿Which tools may I use? Program, JATG, etc... Really i need someone who give me a way to programm, debug, and really to manage all the differents issues and tools to fell sure in this project. 2.- Have anybody use MP3 DEVELOPMENT BOARD with ARM and debugger? I know there is a lot of questions but it is very important for me to know how to iniciate the project and if i have to move to another programming enviroment as IAR. I have probe it and there is a lot of errors depending on compiler version. Thanks in advance!!!! JOSE
Jose Gutierrez wrote: > Hello everyone, > > I am new using LPC2148 and WINARM tools. Before this i worked with IAR > and TI microcontrolers. > > So i have a MP3 DEVELOPMENT BOARD of SPARKFUN and i get the free SW that > SPARKFUN has in its web. I don't know this code so just some general remarks: > I have read that this SW is for WINARM. It should be possible to use any other cross-toolchain based on the GNU tools (i.e. CS G++, Yagarto, DevkitARM etc.). > This programming enviroment is new for me and i am in a mess. > > So i would like someone could answer me several question i have. It > would be great. > > 1.- WINARM is only for programming through programmers notepad. But it > is only to programming, not to debug. Programmers Notepad is just a editor. I expect you mean the menu-item "make program". Does this lead to a call of lpc21isp (see the output-window in PN)? lpc21isp is just a tool that can transfer data into the LPC flash-memory through UART and the build-in bootloader. > I need to debug throuhg a JTAG to > check my program and to find out several mistakes. The question is that > I DON'T KNOW HOW TO DO THIS. ¿Which tools may I use? Program, JATG, > etc... Really i need someone who give me a way to programm, debug, and > really to manage all the differents issues and tools to fell sure in > this project. There are a lot of options from very cheap to very expensive. A very cheap solution: - get a Wiggler-type interface (i.e. the ARM-JTAG from Olimex) to connect the LPC JTAG-pins to a PC. - get a software which can "talk" to your JTAG-interface and provides a gdb-server. i.e. OpenOCD which is free. - get a debugger-software which can talk to a gdb-server. You may use (arm-elf-)gdb which just offers a simple terminal-style interface, Insight-gdb which is a stand-alone programm with a GUI. You may also use ddd and Eclipse which offer GUI frontends for gdb. Search Jim Lynch's Tutorials for ARM "bare-metal" programming for a more detailed introduction. > 2.- Have anybody use MP3 DEVELOPMENT BOARD with ARM and debugger? I neither have this hardware nor do I know the Sparkfun example code. > I know there is a lot of questions but it is very important for me to > know how to iniciate the project and if i have to move to another > programming enviroment as IAR. Usually the setup for commercial tools is much easier but you need a JTAG-interface that is compatible with the tool. All commercial tools offer Evaluation-Versions so you can try yourself. > I have probe it and there is a lot of > errors depending on compiler version. Since you do not give any information on the errors it's difficult to help. At least the startup-code has to be rewritten. For "WinARM" the code has to be compatible with the GNU assembler which is not compatible with IAR's assembler in EWARM. Ready-made IDEs with integrated debugging and support for the GNU cross-toolchain are for example Rowley's Crossworks for ARM and uVision/RV vom Keil/ARM.
Thank you very much!!!! I am going to probe several options. I´ll get in touch again if i still have problem. Best regards!! Bye.
