Forum: µC & Digital Electronics Vref on MSP430 F2013
von N.Z. (Guest)
Hi everybody,
I’m currently working with an MSP430 F2013, and specifically with the AD
Converter SD16_A.
From the Data sheet I can’t figure out what I should exactly do with the
Pin P1.3 (VREF).
It is written that setting REFON brings me an internal reference voltage
of 1.2V (why that low? With such a high resolution, it sounds a little
bit low.)
Well, the main question is: can I use the P1.3 as an Input?
Or is the solution to switch continuously from Input / Reference Voltage
using the SEL register while starting a conversion?
I have to utilize that I/O as an Input, and release an Interrupt each
time it changes its state.
The recommended 100nF Cap would not have an influence in the Input
operation.
Thank you for helping me out!
von Jörg S. (Guest)
Yes
Should be possible.
>operation.
But maybe the Noise on your Input may degrade the Ref-Voltage.
