Forum: µC & Digital Electronics A meteorological station
von Mark (Guest)
Hello,
I wanted to something useful and fun after having finished the A-Levels.
So I thought about building something electronical and i thought about a
meteorological station.
I have so far built an Analog to Digital Converter, so the temperature
sensors shouldn't be the problem, but my electronical knowledge is
delimited. My question is if the rest like connecting a rain sensor is
very difficult? Then i would look for something simplier as a start.
Greetings
Mark
von klaus2 (Guest)
...in general no problem.
humidity is i.e. an capacity sensor
light is LDR
wind is an generator or magnet with hal-sensor
temperature can also be measured by I2C capable sensors, so you can use
a kind of network
display - already some experiences?
KR, Klaus.
von Andreas S. (andreas) (Admin)
That sounds like a good idea for a first project, if you already have a
little experience with microcontroller programming or programming in
general. The good thing about a weather station project is that you can
start with the basics (a simple temperature display) and then gradually
expand into all the different areas of microcontroller programming (more
sensors, data logging to memory card, radio transmission, graphical
display, network interface...).
To measure temperature and humidity accurately I would use the SHT75, it
is a fully calibrated sensor with a digital output. But a simple
thermistor might be better for a start, using it will help you get some
experience with analog circuits.
von Norgan (Guest)
If it is for fun it shouldn't be a problem. Interfacing all kinds of
sensors to an MCU is a common task in embedded development, you'll find
many examples.
At some point you'll find that getting more precision and accuracy
becomes difficult. Something like getting twice as precise requires to
work four times as hard. That's the moment I would stop in a fun project
with that particular sensor and turn to the next sensor :-)
von Mark (Guest)
Yes, my Analog/Digital Converter sent the data straight to a display.
But it was only a small one, I think I will need a bigger one :-)
Well then, I'm gonna try it out and see if it works.
And it doesnt need to be a high precision measuring tool, because it's
only for personal use.
Thanks for your answers!
Greetings
Mark
von Arc N. (arc)
A lower priced alternative to the SHT75 are Honeywells HIH series of
humidity sensors with voltage output e.g. HIH-4010/4020/4021 and
HIH-5030/5031 (with lower operating voltage) or GEs ChipCap (temperature
+ humidity, voltage or digital output).
ChipCaps are available from Digi-Key, HIH from digikey and
Newark/Farnell
