Forum: ARM programming with GCC/GNU tools GCC compiles fuctions without return instruction
Author: Ferdinand Fahlbusch (Guest)
Posted on: 2009-04-01 00:16
Hello.
I´m using an ARM from OLIMEX, the STM32-P103 with a Cortex-M3. I use
eclipse to write my code in C, arm-none-eabi-gcc to compile,
arm-none-eabi-gdb to debug and OpenOCD to interface the microcontroller
trough an ARM-USB-OCD(based on FT2232L), all this in Windows.
My program compiles and runs perfect, the problem is when I add a new
instruction, it doesn´t mather what instruction and where in my source
code, it makes gcc to compile one of my C functions without his return
instruction, causing my program to crash when I run it.
The two compiled versions of my C function are attached to this post.
Here are the last four changing instructions, before and after adding an
arbitrary instruction:
before:
0x200007c4 <RCC_ADCCLKConfig+56>: add.w r7, r7, #20  ; 0x14
0x200007c8 <RCC_ADCCLKConfig+60>: mov   sp, r7
0x200007ca <RCC_ADCCLKConfig+62>: pop   {r7}
0x200007cc <RCC_ADCCLKConfig+64>: bx    lr
after:
0x200007d4 <RCC_ADCCLKConfig+56>: add.w r9, r7, #336860180  ;0x14141414
0x200007d8 <RCC_ADCCLKConfig+60>: lsls  r0, r0, #0
0x200007da <RCC_ADCCLKConfig+62>: lsls  r4, r3, #0
0x200007dc <RCC_ADCCLKConfig+64>: lsls  r1, r3, #0
I think the compiler does something wrong, but I don´t know how adding
an arbitrary instruction causes gcc suddenly to compile wrong a
function. If someone knows where can be the problem I will be very
gratefull.
Thanks
Posted on: 2009-04-01 13:40
From the address, it looks as if this code is located in RAM. And that
your code has stomped all over it!
Generate assembler from the compiler not the debugger. That will show
the code the compiler generated, not the state of the RAM after you
corrupted it. The debugger disassembles whatever is in the memory - good
or bad.
Occam's razor should be applied here. From the gamut of possibilities,
you are selecting the least likely. The GNU compiler is used
successfully for many millions of lines of code throughout the world. It
is unlikely that you have found a bug that easily that no one else has
spotted, and more likely that your code is flawed.
If you cannot see it, your best bet is to post the code, but you should
be looking at buffer overruns, invalid pointers, and modification of
const data through non-const pointers for example.
Clifford
Posted on: 2009-04-01 21:23
Thank you.
I finally found the problem, I knew that my program fitted into yhe RAM,
but the stack is in RAM too, and colided with my code.
Posted on: 2009-04-01 22:19
Ferdinand Fahlbusch wrote:
> Thank you.
... Ah, yes. Stack overflow, I should have mentioned that too. Stacks
grow downward in memory (toward the code in this case).
Note: the original post is older than 6 Months.
webmaster@embdev.netContactAdvertising on EmbDev.net
