Forum: ARM programming with GCC/GNU tools Linker woes, const arrays in Flash
von Toni Räsänen (Guest)
Hello,
I'm using Yagarto, with version info "arm-elf-gcc (GCC) 4.3.2", with
AT91SAM7X128 chip.
I've been working with USB device port, and although it works now, the
linker is giving me trouble. I am running the entire application from
flash, without remapping (i.e. base address 0x0000'0000) and SRAM starts
from 0x0020'0000. Pretty normal bootloader config.
USB code itself is taken from the Atmel's example cdc (serial converter)
project and seems to be fine when run from SRAM.
After linking to Flash, I noticed that linker had allocated few bytes to
SRAM region (copy-paste from resulting intel hex file):
:020000040020DA
:08000000343A0000383A000018
Guessing that this was some USB array, I found the addresses mentioned
from map file:
0x00003a34                languageIdStringDescriptor
0x00003a38                productStringDescriptor
These are referred from a single array (stringDescriptors), and this
array in turn is referred from a struct (all relevant stuff below).
So, it seemed that I had missed an "const" somewhere. But no, it's
there, and to me it seems that all consts needed are there. Is there
something I have missed, or could this be a bug in compiler/linker?
(trouble casting   *array[] to **array or something...)
typedef struct {
    const USBDeviceDescriptor *pFsDevice;                   /// Pointer
to the full-speed device descriptor.
    const USBConfigurationDescriptor *pFsConfiguration;     /// Pointer
to the full-speed configuration descriptor.
    const USBDeviceQualifierDescriptor *pFsQualifier;       /// Pointer
to the full-speed qualifier descriptor.
    const USBConfigurationDescriptor *pFsOtherSpeed;        /// Pointer
to the full-speed other speed configuration descriptor.
    const USBDeviceDescriptor *pHsDevice;                   /// Pointer
to the high-speed device descriptor.
    const USBConfigurationDescriptor *pHsConfiguration;     /// Pointer
to the high-speed configuration descriptor.
    const USBDeviceQualifierDescriptor *pHsQualifier;       /// Pointer
to the high-speed qualifier descriptor.
    const USBConfigurationDescriptor *pHsOtherSpeed;        /// Pointer
to the high-speed other speed configuration descriptor.
    const unsigned char **pStrings;                         /// Pointer
to the list of string descriptors.
    unsigned char numStrings;                               /// Number
of string descriptors in list.
} USBDDriverDescriptors;
#define USBStringDescriptor_ENGLISH_US          0x09, 0x04
#define USBStringDescriptor_LENGTH(length)      ((length) * 2 + 2)
#define USBStringDescriptor_UNICODE(ascii)      (ascii), 0
// Language ID string descriptor
const unsigned char languageIdStringDescriptor[] = {
    USBStringDescriptor_LENGTH(1),
    USBGenericDescriptor_STRING,
// Product string descriptor
const unsigned char productStringDescriptor[] = {
    USBStringDescriptor_LENGTH(12),
    USBStringDescriptor_UNICODE('M'),
    USBStringDescriptor_UNICODE('y'),
    USBStringDescriptor_UNICODE('D'),
    USBStringDescriptor_UNICODE('e'),
    USBStringDescriptor_UNICODE('v'),
    USBStringDescriptor_UNICODE('i'),
    USBStringDescriptor_UNICODE('c'),
    USBStringDescriptor_UNICODE('1'),
    USBStringDescriptor_UNICODE('2'),
    USBStringDescriptor_UNICODE('8'),
    USBStringDescriptor_UNICODE('x')
/// List of string descriptors used by the device
const unsigned char *stringDescriptors[] = {
    languageIdStringDescriptor,
/// List of standard descriptors for the serial driver.
const USBDDriverDescriptors cdcdSerialDriverDescriptors = {
    &deviceDescriptor,
    (USBConfigurationDescriptor *) &(configurationDescriptors),
    0, // No full-speed device qualifier descriptor
    0, // No full-speed other speed configuration
    0, // No high-speed device descriptor
    0, // No high-speed configuration descriptor
    0, // No high-speed device qualifier descriptor
    0, // No high-speed other speed configuration descriptor
    stringDescriptors,
    2 // 2 string descriptors in list
Difficult to analyse with the given information. Please attach the
complete map-file to a message. A minimal example with all needed files
for a "make all" to reproduce the issue would be fine.
The attached file is a minimal project that has this behavior (including
map file from test compile) using the same structure definitions.
Please try this (mind the 2nd const):
const unsigned char *const stringDescriptors[] = {
    productStringDescriptor,
Thanks, that did the trick, although the seconds const somehow seems so
"wrong" to my eye.
Yes, makes sense, when I now think of it. I just never had encountered
this kind of "const to const" situation before.
