Forum: ARM programming with GCC/GNU tools OpenOCD - PCMCIA LPT converter
von Marcin D. (marcind)
Hi
I have just bought PCMCIA 2xCOM + 1xLPT Delock, but I can't program
flash of AT91SAM7S256 - an error occurs:
'C:\Program Files\openocd-2006re82\bin\'openocd-pp.exe -f 'C:\Program
Files\openocd-2006re82\bin\'at91sam7s256-wiggler-flash-program.cfg
# program the onchip FLASH here
Info:    openocd.c:82 main(): Open On-Chip Debugger (2006-08-01 12:00
CEST)
Error:   jtag.c:1122 jtag_validate_chain(): Error validating JTAG scan
chain, IR mismatch
I used normal PC LPT and everything works fine.
My OpenOCD .cfg file is:
#define our ports
telnet_port 4444
gdb_port 3333
#commands specific to the Amontec JTAGKey
interface parport
parport_port 0x378
parport_cable wiggler
jtag_speed 0
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#reset_config <signals> [combination] [trst_type] [srst_type]
reset_config srst_only srst_pulls_trst
#jtag_device <IR length> <IR capture> <IR mask> <IDCODE instruction>
jtag_device 4 0x1 0xf 0xe
#daemon_startup <'attach'|'reset'>
daemon_startup reset
#target <type> <endianess> <reset_mode> <jtag#> [variant]
target arm7tdmi little run_and_init 0 arm7tdmi_r4
#run_and_halt_time <target#> <time_in_ms>
run_and_halt_time 0 30
# commands below are specific to AT91sam7 Flash Programming
#target_script specifies the flash programming script file
target_script 0 reset script.ocd
#working_area <target#> <address> <size> <'backup'|'nobackup'>
working_area 0 0x40000000 0x4000 nobackup
#flash bank at91sam7 0 0 0 0 <target#>
flash bank at91sam7 0 0 0 0 0
Please for help. Thanks in Advance.
von Andreas S. (andreas) (Admin)
Try increasing jtag_speed (higher values mean a slower rate), set it to
10 as a start. Also make sure you choose the correct parport_port (check
in device manager which I/O address your LPT card has).
That said, Cardbus/PCMCIA cards for parallel ports can be tricky. I once
bought one for another parallel port debugger and never managed to get
it to work. The safe bet would be to buy a USB JTAG.
von Spencer O. (ntfreak)
The only pcmcia parallel device i ever got to work was one from quatech
(SPP-100) - however they are not cheap.
It all depends if they emulate  a true parallel port - most do not.
As Andreas said go and but a usb jtag.
Cheers
Spen
Hi
After restarting computer again everything goes good :).
Now it's working. The only change I did, was changing a line
parport_port 0xFFD8. I tried that before but not work.
I have one more question: Do you know how to remap I/O port OxFFD8 to
Ox378,
becouse in some other programs I can't change addresses manually? I'm
using WinXp.
Thanks for help.
