Forum: µC & Digital Electronics Microcontroller with Ethernet Interface
Author: Andreas Höschler (Guest)
I need a microcontroller board for control purposes (reading
anolog/digital inputs, digital outputs, exact timing,...) Many years ago
I was programming a 80C31 unit, so my first approach would be to
purchase a couple of 80C31 chips, develop a corresponding board (PCB)
with RAM and EPROM, purchase an EPROM programmer, develop a BIOS for
this system that allows me to send test programs via a RS232 line from
the PC to the unit. That's how I would have done it 20 years ago.
Is there any easier solution in the meanwhile? I would love to see an
off-the-shelf board with I/O ports (may be 80C31 based, but another
controller would do as well) and ideally an ethernet interface (as a
replacement for the RS232 interface for programming the unit). But I
need an open system, nothing closed with a proprietary windows software
to talk with the unit. So if I want ethernet I suppose I need a linux
based board so that I don't have to write a TCP stack!? That would be
fine, as log as I can write my control code in C and access the I/O
ports. Any recommendations?
Thanks!
Author: Guido (Guest)
this might be interesting for you:
http://www.wickenhaeuser.de/
Regards
Author: Andreas Schwarz (andreas) (Admin) Flattr this
First, forget the 8031 and EPROMs. If you want something 51-compatible,
there are plenty of faster alternatives with Flash-ROM, e.g. by Atmel
and Maxim. The easiest way to add an Ethernet interface to that is the
ENC28J60. A few good IP stacks are available for free (uIP would
probably be the best in this case).
But you will need a C compiler, so you might just as well start with a
modern controller architecture, like something ARM-based. The AT91SAM7X*
comes with built-in Ethernet, and you can get free example programs,
some with RTOS, for many of the popular boards. If you want Linux, you
need a bigger controller, but it doesn't make sense to use Linux just
for Ethernet/IP.
If that's all too much and you just want a simple drop-in RS232
replacement, take a look at the Lantronix Xport. It will work fine even
with the real 80C31.
Author: Bernd G. (Guest)
www.cyantechnology.com
Author: Win (Guest)
Perhaps this is something for you:
http://www.pollin.de/shop/shop.php?cf=detail.php&p...
Author: Peter Dannegger (peda)
If you want to use 8051, then look on the Maxim DS80C400 Evaluation Kit:
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/4983
The DS80C400 contain a single cycle 8051-core whith 16MB address range,
four data pointers and 16/32-Bit Math Accelerator.
The internal Ethernet controller supports Network Boot Over Ethernet
Using DHCP and TFTP.
Peter
Author: damien HOYEN (Guest)
I have been using a STR912 with an ethernet embedded communication, 6
months ago.
This microcontroler is interesting because:
- ARM9 core
- Plenty of RAM: 96K, Until 2Mb of Flash,
- Embedded TCP-IP interface
- Available in TQFP package (easy for soldering / design)
- Supported by : GCC , FreeRTOS (RTOS), UIP (stack TCP) and OpenOCD (al
these tools are opensource)
- Cheap demo board (Olimex STR912)
- Low cost processor
But
- Not easy to start
- Not as documentation as you could find for the very well know Atmel
At91, especially for embedded Linux
Regards.
Damien hoyen
