Attached files:Morning All. I am trying to get a c++ debug example running on my AT91SAM7S256. I have downloaded the example at91sam7s_cpp from http://www.siwawi.arubi.uni-kl.de/avr_projects/arm... I am trying to run this in Eclispe using openocd and ARM-USB-OCD. I have already sucessfully run a C program from Eclipse in debug, but want to get a C++ example running as I intend to write my app using OO and C++. My questions are: 1) When running the C program from Eclipse the Compiler invocation command is set to C:\gccfd\yagarto\bin\arm-elf-gcc.exe, shuold I change this for C++? to arm-elf-g++.exe? or something else 2) For the debugger options I have C:\gccfd\yagarto\bin\arm-elf-gdb.exe, is that correct for C++? 3) The make file which came with the example compiles for ROM (final) and not RAM (debug), I have changed this throughout and the project builds without error, but when I try to debug I get the error No source available for "main() " - View Disassembly I have attached a copy of the modified make file. I feel Im almost there - but not quite (or may not!) Anyway, time to ask for some advise, so any help would be greatly appreciated. Thanks XS.
Sorry, subject is wrong! should read need help with at91sam7s_cpp, but as it happens the make file in the download for Example: at91sam7s64_cpp wont build!
Hi Sam, I have currently exactly the same problem. Did you solve it meanwhile ? Thanks Marcel
