Forum: ARM programming with GCC/GNU tools interrupt style for LPC23xx?
Author: Raed Abusanad (raedbenz)
hi which is the correct form for interrupt?
void irqhandler (void)__irq  or
void IRQ_Routine (void)   _attribute_ ((interrupt("IRQ")));
could u clarify the meaning of 2nd style argumemnts??
thakns
depends
This can either be a vendor-specific extension (i.e. RV, EWAVR,...) or a
macro.
This is the GNU attribute for IRQ "interrupts". So if you use a GNU
toolchain (arm-*-gcc) this one can be used but I suggest to use an
assembler wrapper instead to avoid compiler-dependencies in the C code.
Which compiler/toolchain is in use?
> depends
> macro.
hi,
thanks for the reply,,,
i am using Eclipse with Yagarto toolchain, and the IRQs are defined with
2nd style, but i havent managed yet to run them. on the other hand in
WinARM there are examples that they use the 1st style although uses GNU
toolchain.
do u know where can i get examples for eclipse/yagart for LPC23xx ??
thanks
>> depends
>> macro.
> hi,
This should work in most cases. Verify that you do not mix code that
uses a wrapper with code that uses IRQ attributes.
> toolchain.
In some of my examples I heavily re-used code which has been made for
another toolset. Please search the mentioned examples for #define __irq,
you should find it and defined as empty. So in this examples void
irqhandler (void)__irq is the same as void irqhandler (void). Since
"irqhandler" is a "normal" c-function without any attributes the example
should include a assembler-wrapper, search the .S-files of the project
for it.
> thanks
Hi ,,
still cant run the interupt of timer 0.
could plz have a look to my code (attached) and give me your opinion??
thanks
Author: Klata (Guest)
You must unlock interrupt in file crt.s
is:
    sub   r0, r0, #SVC_STACK_SIZE
        msr   CPSR_c, #MODE_SYS|I_BIT|F_BIT   /* User Mode */
        mov   sp, r0
should be:
        msr   CPSR_c, #MODE_SYS|F_BIT   /* User Mode */
        mov   sp, r0
Author: raedbenz (Guest)
hi,,
thanx for the reply..but still doesnt work..
cheers
