Forum: ARM programming with GCC/GNU tools Eclipse + ARM-gcc toolchain
Author: Michael Rodrigues (michael_rodrigues)
HI,
I got the eclipse platform ver 3.4.1 from the yagarto website. This was
a zipped file, so i unzipped it into D:\Data\eclipse\. before this i
downloaded the yagarto toolchain and installed the same (defualt
location, program files, C:).
Now my problem is, when i start eclipse, start a new project and try to
select a toolchain in the toolchain editor, i can only see a no
toolchain setting over there. How do i configure it to the yagarto
toolchain.
Michael Rodrigues wrote:
> HI,
> toolchain.
AKAIK there is no out-of-the-box support in Eclipse for a
Cross-Toolchain as in Yagarto. At least I have not found it in the
current Eclipse (Ganymede). Did you read Jim Lynch's Tutorial available
i.e. from atmel.com? Use a makefile-project and set the compiler for the
parser to arm-elf-gcc and configure the search-pathes for include-files.
There is at least one 3rd party Eclipse-plugin for arm-*-gcc (see
sf.net) but I don't know much about it. For debugging configure a
debug-setup using the GDB hardware-debugging plugin (from the "official"
Eclipse repository) or the 3rd party plugin from Zylin plugin that comes
with Yagarto.
Author: Useless !!!! (useless)
>> HI,
>> toolchain.
If you are using Windows, setting up an ARM toolchain is simple.Since
you have already downloaded Eclipse and installed Yagarto, just use the
GNUARM Eclipse plugin found at
http://sourceforge.net/projects/gnuarmeclipse/. It has out of the box
support for Yagarto. Just download the '.jar' file into the Eclipse
plugin folder.
Author: Ziga Lausegger (Company: PeF Ljubljana, TSC Kranj) (zigalausegger)
> plugin folder.
What if i use Linux Ubuntu??? Is there any way to do it? I only want to
use codesourcery toolchain in eclipse.
Author: Oliver (Guest)
Eclipse, the gnuarm plugin, and codesourcery all run under Linux. Just
install, and be happy ;)
Oliver
I did folow a tutorial here:
" http://mbed.org/cookbook/Using-mbed-with-gcc-and-eclipse ".
I ended up getting an error and a warning. Take a look at the picture to
see my warning/error.
Double check if the PATH has been extended according to "Edit PATH and
add..." in the mentioned tutorial
Here it is... this is how i did it...
I tried to install it allover again and at step 3 where i am supposed to
add ARM GCC plugin .zip file i cannot click "Finish" button ... Why is
that? Any other way?
I managed to install it allover again and i dont get warnings about :
"cannot find arm-none-eabi-gcc". Instead when compiling i get 2 other
errors saying "cant find startup.o" and "make: *** [test_balau.elf]
Error 1"
Author: camilo chaves (Company: Student) (bikebogota)
I think it is ok to don't see yagarto toolchain in Eclipse, I mean, you
can use it but you won't see it there. In fact, as the tutorial says,
you have to select Neew Project->MakeFile Project [Other Tool chain].
No. If the gnu-arm-plugin for Eclipse is installed properly, you will
see arm-toolchain projects, and you can select the yagarto-toolchain.
Well, the linker might want to tell you, that something called startup.o
is missing. If you have a "startup.s" in your source file folder, rename
is to "startup.S". For some unknown reason Eclipse recognizes only files
with .S (capital S) as assembler source files.
Oliver
Author: ziga lausegger (Guest)
Wow, this is really nice info. Thank you.
