Forum: ARM programming with GCC/GNU tools -gc-sections breaking debugger
von Alfredo C. (tequilaguru)
I been working on a set of tools for a lpc2387 board I developed,
I built openocd(trunk), gcc(4.3.2) and insight(6.8) under Cygwin, those
work very well, I have scrips to download code and to debug the target.
Those work great as well, but I have a problem.
If a build the code with:
LINKER_FLAGS=-nostartfiles -Xlinker -o$(BUILDDIR)/lpc2387.elf -Xlinker
-M -Wl,-Map=$(BUILDDIR)/lpc2387.map,--cref,--gc-sections
and
CFLAGS= $(DEBUG) \
    $(OPTIM) \
    -T$(LDSCRIPT) \
    -mcpu=arm7tdmi \
    -I$(INCLUDEPATH)\
    -D PACK_STRUCT_END=__attribute\(\(packed\)\) \
    -D ALIGN_STRUCT_END=__attribute\(\(aligned\(4\)\)\) \
    -fomit-frame-pointer \
    -mthumb-interwork  \
          -ffreestanding    \
          -ffunction-sections     \
         -fdata-sections    \
The debugger won't allow me to step over to the next line of code, if I
remove the -gc-sections parameter (thus removing dead code elimination)
the debugger will work as expected.
Although the debugger is working, is very annoying to have to step line
per line of code, I can set temporal breakpoints but may be someone had
this problem before?
Alfredo Cabral wrote:
Further examination reveals, it was only with the first function.
The rest of the debugging session works as expected.
von Spencer O. (ntfreak)
generally if using -gc-sections breaks your code then you need to check
the linker script.
Do you have the KEEP sections correctly defined (usually on the reset
vector)?
Cheers
Spen
> the linker script.
> vector)?
> Cheers
> Spen
Spen,
The code compiled and linked fine, the thing is, while debugging it was
impossible to step over a function, Insight jumped into everytime,
however this only happened on a very specific binary, most compiles work
ok, and those that exhibit anomalies, only do so on the very first
function. It drove me nuts at some point because I thought this wasn't
an isolated case, but as I explained above, turns out it was.
Cheers
Alfredo
