Forum: ARM programming with GCC/GNU tools setting Eclipse - FTD2XX.dll not found
Author: Raed Abusanad (raedbenz)
hi,,
i have managed to compile a test code and get the executable with the
steps in Yagarto/Eclipse Website.
But when i try to set up the debugger in in step 2(from web) "Native GNU
ARM toolchain for windows", and i type in cmd window
"D:\Projekte\ARM\STR7Test>openocd-ftd2xx -f .\prj\jtagkey.cfg" i get
that an error says that FTD2xx.dll not found. i gues that i am getting
that bcoz i have not installed JTAGkey drivers???? but i dont have the
hardware , i think i ashould be able to debug the code without a JTAG???
just by looking how variables change values, etc..
thanks??
Author: Jonathan Dumaresq (dumarjo)
Raed Abu-sanad wrote:
> hi,,
> thanks??
FTD2xx-dll should be on your openocd installation directory.
it's probably an environement variable that it's not set correctly. If
you want  to test, put that dll in your windows\system32 directory.
Jonthan
> Jonthan
hi, here is wat i am getting:
E:\Downloads\STR7Test>openocd-ftd2xx -f .\prj\jtagkey.cfg
Open On-Chip Debugger (2008-06-19 19:00) svn: 717
URL: http://svn.berlios.de/svnroot/repos/openocd/trunk
Info:    options.c:50 configuration_output_handler(): jtag_khz: 10,
16000
Info:    options.c:50 configuration_output_handler(): Open On-Chip
Debugger (2008-06-19 19:0717
Error:   ft2232.c:1419 ft2232_init_ftd2xx(): unable to open ftdi device:
hints plz?
thanx
> but i dont have the
I guess you are looking for a simulator. A rather simple core-simulator
is included in gdb, try target sim. Should at least help during the
first steps.
Neither OpenOCD nor FTDI-driver will help you if you do not have a
JTAG-interface and a controller to connect to.
Martin Thomas wrote:
>> but i dont have the
> first steps.
hi,,thanks.
do u have any idea how do i configure and run the simulator?
thanks
Author: Intelitez Intelitez (Company: intelitez) (intelitez)
my openocd test viacmd line shows - FTD2XX.dll not found
please provide steps to rectify
Author: Jim Meba (turboj)
Current OpenOCD versions should not need FTD2XX.dll any longer.
OpenOCD with ftdi driver requires WinUSB AFAIK.
