Forum: ARM programming with GCC/GNU tools Problem with eclipse and yagarto when compiling
von Franz M. (beaver)
Hi all!
I installed yagarto on my Laptop as described on the homepage and also
tested the installation by calling
arm-elf-gcc main.c
wihtin my windows-commandline. The output file was created so i assume
the compiler is working.
In eclipse i set the compiler invoke-command - path to the
arm-elf-gcc.exe as well.
Nevertheless i get the following error within eclipse when trying to
clean or build a file/project:
**** Clean-only build of configuration Default for project TestLPC ****
(Cannot run program "make": Launching failed)
I don´t know, why make cannot be launched.
Any help would be very appreciated ;-)
Thanks and kind regards,
Franz
von Giovanni D. (gdisirio)
Franz Maier wrote:
> Hi all!
> arm-elf-gcc main.c
> Franz
Is the make.exe in your system path ? If I remember well it is in the
YAGARTO OpenOCD package under openocd-rxxx\utils\bin
regards,
Giovanni
ChibiOS/RT http://chibios.sourceforge.net
