Forum: ARM programming with GCC/GNU tools Eclipse Internal Builder (managed make) support?
von Joe D. (jdupre)
What happened to the Internal Builder option (managed make) in the
current version of Eclipse for C/C++ developers ("Ganymede")?  The
managed build plugin is in there, but the only option when creating a
new project is to use the Makefile Project type.  In the C/C++ Build
options dialog, External Builder is the only option.
Is there some other plug-in required to enable used of the managed build
system?
[ If I import an old Eclipse project that used the managed build system
into the current version, then it appears to work.  I just can't create
new projects using the internal builder. ]
von Clifford S. (clifford)
Are you sure that this is the most appropriate forum for this question?
This is not the Eclipse CDT project. Your question should perhaps be
directed at http://www.eclipse.org/cdt/
von Joe D. (jdupre)
You are absolutely right.  Michael Fischer, perhaps you can add that
link to your yagarto support page.  (Or more specifically,
http://www.eclipse.org/newsportal/thread.php?group=eclipse.tools.cdt )
In regards to my question, the reason the managed make options were not
appearing was because I did not have the MinGW toolchain (or other
supported toolchain) installed.  It is possible to use the managed make
features with yagarto and WinARM once Eclipse finds a "valid" GCC
toolchain.
- J
