Forum: ARM programming with GCC/GNU tools SWI.H and IAR
Author: Andy Kunz (montanaandy)
I am attempting to port Martin's at91sam7_chanfat demo to run under IAR
in order that I might debug some hardware.  The problem is that SWI.H is
not syntactically correct for the IAR compiler.  The compiler gives up
trying to process function do_SWI, giving up on the lines starting with
  asm (
    "mov r0, %2 \n\t" \
    "mov r1, %3 \n\t" \
    "mov r2, %4 \n\t" \
    "mov r3, %5 \n\t" \
    "swi %a1    \n\t" \
    "mov %0, r0 \n\t" \
    :  "=r" (ret_val)
    :  "I" ((const int)swi_num),
      "r" (par0), "r" (par1), "r" (par2), "r" (par3)
    :  "r0", "r1", "r2", "r3", "ip", "lr", "memory", "cc"
I was wondering if anybody has successfully ported either SWI.H to IAR,
or perhaps the project.
Thanks.
Andy
Author: Andy Kunz (horizonandy)
I gave up on the port, per se.
Instead, I used the latest CHaN package (0.06) and his sample code,
integrating the FF.*, MMC.C and DISKIO.H files into the IAR BASIC
package.  That gave me the ability to debug the low-level operations
successfully on my hardware.  Turned out I had a third-party SPI device
that didn't de-assert MISO when it was not selected :(
Andy
Andy Kunz wrote:
>   asm (
>     "mov r0, %2 \n\t" \
>     "mov r1, %3 \n\t" \
>     "mov r2, %4 \n\t" \
>     "mov r3, %5 \n\t" \
>     "swi %a1    \n\t" \
>     "mov %0, r0 \n\t" \
>     :  "=r" (ret_val)
It seems perhaps that you have solved/worked around this already,
however for future reference it may be worth noting that inline
assembler syntax is not standardised amongst C compilers and that GCC's
syntax is particularly arcane (albeit very powerful). You will probably
need to understand the inline asm syntax of both compilers to perform a
successful port. Information on GCC syntax is minimal; I have used
http://www.ibiblio.org/gferg/ldp/GCC-Inline-Assemb... in the
past - the examples are all in x86 assembler, but it is the syntax not
the instruction set that you are interested in.
Looking at the IAR manual (
http://www.iar.com/website1/1.0.1.0/78/1/index.php ) the syntax looks
broadly similar, however it does not appear to have the syntax to define
the interface between the asm and the C code that GCC has, or for
allowing the compiler to select registers rather than specifying them
specifically. Basically IAR is not as flexible or powerful in this
respect. I suspect that to port this it would be safer to use the full
IAR assembler and code it as a C callable function rather than inlining
it.
Clifford
