Forum: ARM programming with GCC/GNU tools default lib path form arm
Author: Giuseppe Monteleone (geppo)
hi all
I'am using eclipse ganymede with WINARM. I can't compile because system
connot find system libraries.
before eclipse i used gcc frontend also for linking, but eclipse use ld
directly.
How can configure eclipse with correct default library path ?
Thanks
Ing Giuseppe Monteleone
Giuseppe Monteleone wrote:
> hi all
> directly.
Does it? Do you use any plug-in/extension? You can always use a makefile
project, which may be a little more complicated first but might be
easier to manager later (just one text file instead of several
dialog-boxed to remember).
Did you select arm-elf-gcc (not just gcc) in the scanner/build settings?
