Forum: ARM programming with GCC/GNU tools Variable Storage area
Author: Amit Chatre (aseem)
        I assign a variable int x=55; please tell me storage area in
memory.
if it will store in data memory,please what is the way to store it in
code memroy?
Thanks,
Aseem
Amit Chatre wrote:
> Hi,
> memory.
Generate a map-file (-Wl,-Map=mymapfile.map when linking with gcc), it
shows the location.
> code memroy?
Test with const int x=55;
Amit Chatre wrote:
> Hi,
> memory.
That depends on the storage class of the variable. Non-static local
variables are stored on the stack so are non-deterministic. Either way
you can determine the address at run-time with &x
> code memroy?
> Thanks,
> Aseem
What is it you are actually trying to achieve. Neither the
compiler/linker not the ARM architecture have any concept of 'code' or
'data' memory, code may be executed from ROM or RAM. Did you simply want
to store the data in read-only memory?
It has been suggested that you use the const keyword, but the compiler
is not obliged to store such data in ROM. The semantics of const is
merely that the code cannot modify the data.
To place variables in specific memory areas in GCC you myst use a
section attribute to place the data in a section defined in the linker
script.
http://gcc.gnu.org/onlinedocs/gcc-4.3.2/gcc/Variab...
Clifford
Thank you for all this,
Clifford Slocombe wrote:
> Amit Chatre wrote:
>> Hi,
>> memory.
by using const keyword I'm able to save data in read only memeory.
>> code memroy?
>> Thanks,
>> Aseem
Actually I wanted to store const defined variables in ROM.
now suppose if I have a variable array of int
const unsigned int i[1024]={
then it should be store in flash memroy.
> script.
> Clifford
Again ther is one problem,
how can I define a variable external memroy by default.
means if i defined a variable
const int XL[10];
its memory address would be 0xA0000000.
Please tell me how can I do this?
Or any suggestion or link about memory interfacing and samples codes.
I'm totally new for memory interfacing.....
Thanks in Advance.
Aseem
The answer to your question is as I suggested - use a linker section
attribute.
const unsigned int i[1024] _attribute_ ((section ("ROMDATA"))) =
const int XL[10] = _attribute_ ((section ("MYLOCATION"))) =
Note that here ROMDATA and MYLOCATION must be defined in the linker
script. You can define them as absolute addresses or a relocatable
section. As described here:
http://www.math.utah.edu/docs/info/ld_3.html#SEC14
Clifford
