Forum: ARM programming with GCC/GNU tools Wait states for reading and writing flash
von Vinit B. (vinitbidkar)
CPU - AT91SAM7X256
Which factor decides the number of wait states required for reading and
writing the flash.
i am running the cpu at 32 MHz, so how many wait states are needed for
reading and writing flash?
Vinit
von Clifford S. (clifford)
Vinit Bidkar wrote:
> CPU - AT91SAM7X256
> writing the flash.
At the risk of sounding like I am saying RTFM (which I am), the answer
is on page 612 of
http://www.keil.com/dd/docs/datashts/atmel/at91sam7x128_256_pc.pdf
Since you only get single cycle access at or below 30MHz, you may find
that you get better performance by reducing the clock slightly so you
can use zero wait state.
A newer revision of the manual is available at
http://www.atmel.com/dyn/resources/prod_documents/doc6120.pdf but it is
a far slower download. In this revision it is on page 627.
Clifford
Clifford Slocombe wrote:
> Vinit Bidkar wrote:
>> CPU - AT91SAM7X256
> is on page 612 of
> Clifford
Thanks a lot Clifford.
I will consider your inputs. Also i think i should have searched the
datasheet bit more thoroughly :-)
