Forum: ARM programming with GCC/GNU tools Trouble in SAM-BA USB programming
von Sara S. (slsm)
I've built a custom board with the AT91SAM7S and tried to program it
using
SAM-BA v2.6 (with USB connection).
I've copied the boot stuff from the SAM7S-EK schematic:
- LED to PA0 from resistor and 3V3
- Pull-up on PA1/2
- USB pull-up controlled by PA16
- TST switchable to high for bootloader recovery
- 18.432 XTAL
and performed the bootload copy by closing JP5 (TST), applied power,
wait
10 seconds, power down.
but after that when I connect the board to PC it says "usb device not
recognized".
and when I run SAM-BA there is only COM ports in the list and I can't
find and select USB connection!
Any ideas on what to do?
Regards,
Sara
von Nils S. (nilswed)
Sara slsm wrote:
> Hi,
> using
> - Pull-up on PA1/2
> - 18.432 XTAL
> wait
> recognized".
> Regards,
> Sara
Hello Sara,
you must use the correct .inf-file and its correct driver. I have been
into this problem myself, spent an awful lot of time solving it.
Unistall the driver via the hardware controlling program
(system-hardware etc) and use ATM6124.inf and ATM6124.sys to reinstall.
They are attached in the zip file.
Good luck,
Nils in rainy Sweden
von Sara S. (slsm)
> Hello Sara,
> Good luck,
Thanks Nils
but how should I reinstall them, I try by Update driver but it wasn't
useful !
Regards,
Sara
Sara slsm wrote:
>> Hello Sara,
>> Good luck,
> Thanks Nils
> useful !
> Regards,
> Sara
Be my guest...!
You select UNINSTALL to remove the driver. Then you reattach the board.
The "New Hardware" ought to pop up. After that you actively install the
device by selecting the directory where you saved the files I sent you.
Keep only the files I sent you in that directory, no other files! Dont
let XP select the install files for you!
Encore: Good luck,
Nils from sunny Sweden
von Sara S. (slsm)
> Be my guest...!
> Encore: Good luck,
Hello
Windows don't let me to do that, I checked my board,I think there is a
problem with my board.
microcontrller doesn't answer to host requests!and therefore host
doesn't know device is of which class!
Any idea on this problem?!
Regards,
Sara
Sara slsm wrote:
>> Be my guest...!
>> Encore: Good luck,
> Hello
> Regards,
> Sara
Hello Sara,
I think Windows are using the wrong driver when you get the error msg
"usb device not recognized". It probably talk with your board but get
information it doesn't like from it because the driver it finds for the
board don't match the installed inf-file. In my case it was an installed
driver for VID 6124, installed when I first time attached the
AT91SAM7S-EK-board, which interfered with the driver the bootloader
need. The problem is that Atmel bootloader uses the same VID and PID as
the -EK-board! So I had to uninstall even the register information for
that board and begin from scratch with the installation. Jan Axelson's
book USB Complete which I bought taught me that. Keep the normal driver
and inf-file for the AT91SAM7S-EK-board FAR away from Windows when you
reinstall your board!
Once more: good luck!
Nils
von Sara S. (slsm)
Hello Nils,
thanks very much for your help.
This error isn't only for not matching driver,an other way to get this
error without using any device,only use a 1.5 k resistor:
place the Resistor between D+ and VCC cable of the USB cable which is
connected to your PC. :)
I read Jan Axelson's book USB Complete before, it was a good source to
help in doing my project with USB.
As I say in my first post, I use a custom board therefor I don't have
normal driver and inf-file for the AT91SAM7S-EK-board.
Regards,
Sara
Sara slsm wrote:
> Hello Nils,
> Regards,
> Sara
Sorry Sara,
I stand corrected, did not try the 1k5 resistor myself! It is good to
know! I made several customs boards in parallel with using the -EK board
as sw-tryout. That is why I had problems with wrong drivers, forgetting
what you wrote before. (I JUST found a bug which has been eluding me for
several weeks, have had difficulties concentrating on other stuff!)
Reading your earlier posting I cannot imagine what can be wrong, you
seem to have all things correct, still I think the problem lies with the
driver. Jan A has an entry describing old driver removal, have you read
that?
I was sure I also had problem with my hardware, even as I designed  the
USB hardware part exactly as in the Atmel CPU manual. BUT my last 3
boards is today running, with the correct driver. A lot of work in vain,
could have kept the first board design!!!
Best wishes,
Nils
Nils Soderman wrote:
> Sara slsm wrote:
>> Hello Nils,
>> Regards,
>> Sara
> Sorry Sara,
> that?
> Best wishes,
> Nils
Sara, another thing I found out is that the schematics for
AT91SAM7S256-EK did not work in my case, the 100 kOhm resistor into the
USB-detect never indicated unattached USB cable. Instead I used the
voltage divider descibed in the manual of the CPU: change the 100 k
resistor to a 27 k resistor. On the "inside" (between CPU and resistor)
put a 47 k resistor  with other side to ground. This will give a stable
logic level both with attached and unattached cable!
Nils
