Forum: ARM programming with GCC/GNU tools memcpy problem
von ezequiel (Guest)
Hello,
I have a little problem with memcpy,and eventhough I have read other
topics and try to solve it, I couldn't My WinARM Version is 4.1.1
I have an structure very basic, called Rect. I wanted to pass this
structure to a function this way:
void getRectSize (Rect rectangle){
but when compilling it says "undefined reference to `memcpy'". So I
added to my make file the option -lgcc -lc, in the linker part. But now
it says: c:\WinARM\bin\arm-elf-ld.exe: cannot find -lgcc
This is my makefile:
NAME       = M1
MCU    = arm7tdmi-s
CC        = arm-elf-gcc
LD        = arm-elf-ld -v
AR        = arm-elf-ar
AS        = arm-elf-as
CP        = arm-elf-objcopy
OD    = arm-elf-objdump
SIZE    = arm-elf-size
CFLAGS    = -mcpu=$(MCU) -I./include -c -fno-common -g
AFLAGS    = -mcpu=$(MCU) -ahls -mapcs-32 -o crt.s
LFLAGS    = -Map main.map -lgcc -lc -lm -T./src/2106.cmd
CPFLAGS   = -O ihex
ODFLAGS    = -x --syms
all: M1 size
main.out: crt.o delay.o main.o system.o ./src/2106.cmd
  @ echo "..linking Main"
  $(LD) $(LFLAGS) -o ./release/main.out ./release/crt.o
./release/delay.o ./release/main.o ./release/system.o
delay.o: ./src/delay.c
  @ echo ".compiling delay.c"
  $(CC) $(CFLAGS) ./src/delay.c -o ./release/delay.o
system.o: ./src/system.c
  @ echo ".compiling System.c"
  $(CC) $(CFLAGS) ./src/system.c -o ./release/system.o
main.o: ./src/main.c
  @ echo ".compiling Main.c"
  $(CC) $(CFLAGS) ./src/main.c -o ./release/main.o
crt.o: ./src/crt.s
  @ echo ".assembling CRT.S"
  $(AS) $(AFLAGS) ./src/crt.s > ./release/crt.lst -o ./release/crt.o
How can I solve this problem.. I cannot continue making a clear program
without the features that memcpy gives.
Thanks very much.
Ezequiel
ezequiel wrote:
> LD        = arm-elf-ld -v
Try to link thru the compiler-frontend (arm-elf-gcc). It "knows" the
needed search-path.
Martin Thomas
von Guest (Guest)
Thanks very much Martin, What changes do I have to make on the make
file?
Martin Thomas wrote:
> ezequiel wrote:
>> LD        = arm-elf-ld -v
> needed search-path.
> Martin Thomas
> file?
Most (all?) of the examples I provide use the compiler-frontend to call
the linker, the makefiles in the examples can serve as templates.
Martin Thomas
>> ezequiel wrote:
>>> LD        = arm-elf-ld -v
>> needed search-path.
>> Martin Thomas
von Dmitry T. (cryon)
Hi!
Please, has anybody solved the problem?
I have the same error message...
von Clifford S. (clifford)
Dmitry Timas wrote:
> Hi!
Did you try the solution Martin suggested?
Thanks a Lot! Eventually I ended up using Martin’s solution (found in
the project lpc_2129_adc_stdio_20070313). It works fine for me!
