Forum: ARM programming with GCC/GNU tools looking for ARM usb bootloader
von Daniel D. (dandumit)
I'm willing to start to learn arm.
I have bought the board : http://www.olimex.com/dev/sam7-p256.html
I have made some tests loading the code in flash using SAM-BA.
Is any bootloader available in order to send the code in controller at
the moment when the board is connected to pc trough usb cable ?
Regards,
Daniel
von Alex S. (alessio)
Check out TNkernel webpage:
http://www.tnkernel.com
under USB firmware upgrader.
It is written for LPC2xxx MCU's, but you can get basic idea.
Regards,
Aleš
Daniel Dumitru wrote:
> Hi,
For development you should try to get a JTAG-interface. Support for
flash-programming of AT91SAM7S in the free software OpenOCD is rather
good and the adapters like the Olimex ARM-JTAG or Amontec JTAGkey/-tiny
are rather inexpensive. You can also use these FT2232-based adapters for
debugging.
Some SAM7 USB bootloader-codes:
http://cq.cx/at91sam7sXXX.pl
http://www.pcb-dev.com/ -> SAM7 Flashtool
