Forum: ARM programming with GCC/GNU tools GDB Warnings & Failure - JTAG USB OCD Tiny & Eclipse
Author: Tharon Hall (tharonhall)
I have been trying since yesterday to get a valid SAM7 development
environment going.
Hardware:
Olimex SAM7-EX256 development board
Olimex JTAG USB OCD Tiny
Software:
Started with: Olimex "WinARM" for Dummies install
 -After issues, updated the following:
Eclipse - Updated to latest
Eclipse CDT - Updated to latest
Zylin - Updated to latest
Cygwin - Updated to latest
yagarto - Updated to latest
OpenOCD - Updated to latest from yagarto
Source Code:
USB-RS232 Sample Code downloaded from Spark Fun
SAM7EX256 Ethernet Eclipse project from FreeRTOS
One thing I can definitely say is that this debug environment is no
where near "plug and play". I don't want to list all the things I have
had to play with to get as far as I have.
I am almost at wits end. As you can see, I have been trying everything I
can imagine to get my configuration working.
Now, to the problem:
I finally have both project compiling just fine. I can also start
OpenOCD, though I do get an error and some warnings as given below:
Info:    openocd.c:93 main(): Open On-Chip Debugger (2007-09-05 09:00
CEST)
Error:   arm_jtag.c:38 arm_jtag_set_instr_error_handler(): setting the
new JTAG instruction failed,
debugging is likely to be broken
Info:    target.c:232 target_init_handler(): executing reset script
'sam7flash.script'
Info:    configuration.c:50 configuration_output_handler(): requesting
target halt...
Warning: arm7_9_common.c:933 arm7_9_halt(): target was already halted
Info:    configuration.c:50 configuration_output_handler(): target
already halted
Info:    configuration.c:50 configuration_output_handler(): waiting for
target halted...
halted
Info:    configuration.c:50 configuration_output_handler(): dcc
downloads are enabled
target halted...
halted
Info:    configuration.c:50 configuration_output_handler(): core state:
ARM
Info:    configuration.c:50 configuration_output_handler(): flash
'at91sam7' found at 0x00100000
Info:    configuration.c:50 configuration_output_handler(): #0: at91sam7
at 0x00100000, size 0x00040000,
buswidth 4, chipwidth 0
0x00000000 (0x40000kB) erase state
unknown, protection state unknown
Info:    configuration.c:50 configuration_output_handler(): at91sam7
information: Chip is AT91SAM7X256
Info:    configuration.c:50 configuration_output_handler(): cidr:
0x275b0940, arch: 0x0075, eproc:
ARM7TDMI, version:0x000,  flashsize: 0x00040000
Info:    configuration.c:50 configuration_output_handler(): master
clock(estimated): 54275kHz
Info:    configuration.c:50 configuration_output_handler(): pagesize:
256, lockbits: 16 0x0000, pages in
lock region: 64
Info:    configuration.c:50 configuration_output_handler(): securitybit:
0, nvmbits: 0x4
Info:    configuration.c:50 configuration_output_handler(): cleared
protection for sectors 0 through 15 on
flash bank 0
Info:    configuration.c:50 configuration_output_handler(): erased
sectors 0 through 0 on flash bank 0 in
0s 46875us
Info:    configuration.c:50 configuration_output_handler(): wrote  8496
byte from file main.bin to flash
bank 0 at offset 0x00000000 in 1s 62486us (7.808926 kb/s)
I don't know if that is a problem or not.
I then try and launch gdb. I get some strange warnings:
source .gdbinit
Warning: /cygdrive/C/gccfd/projects/sam7ex256/include: No such file or
directory.
Warning: /cygdrive/C/gccfd/projects/sam7ex256/drv_inf: No such file or
directory.
Warning: /cygdrive/C/gccfd/projects/sam7ex256/Compil/srcWinARM: No such
file or directory.
Warning: /cygdrive/C/gccfd/projects/sam7ex256/Compil/srcIAR: No such
file or directory.
Warning: /cygdrive/C/gccfd/projects/sam7ex256/Compil/Resource: No such
file or directory.
Warning: /cygdrive/C/gccfd/projects/sam7ex256/Compil: No such file or
directory.
Warning: /cygdrive/C/gccfd/projects/sam7ex256/.dep: No such file or
directory.
Warning: /cygdrive/C/gccfd/projects/sam7ex256: No such file or
directory.
directory.
directory.
file or directory.
file or directory.
file or directory.
directory.
directory.
directory.
No registers.
The debug window indicates the following:
sam7ex256 Debug [Zylin Embedded Degu(Cygwin)]
   Embedded GDB (7/19/08 5:14 PM) (Suspended)
   c:\gccfd\yagarto\bin\arm-elf.exe (7/29/08 5:14 PM)
I suspect an issue with cygwin, so I run bash and get the following:
tharon@tharonpc ~
$ cd /cygdrive/c/gccfd/projects/sam7ex256
tharon@tharonpc /cygdrive/c/gccfd/projects/sam7ex256
$ ls
AT91SAM7S-EK.h     interrupt_Usart.lst  main_org.o
Compil             interrupt_Usart.o    openocd_env_info.cmd
Makefile           main.bin             openocd_go_flash.cmd
armusbocd.cfg      main.c               readme.txt
cdc_enumerate.c    main.elf             sam7flash.script
cdc_enumerate.h    main.lss             sam7s_usb_uart.pnproj
cdc_enumerate.lst  main.lst             sam7s_usb_uart.pnps
cdc_enumerate.o    main.map             swi_handler_user.c
drv_inf            main.o               swi_handler_user.lst
include            main.out             swi_handler_user.o
interrupt_Usart.c  main.sym
So, when I try the directories that are giving it trouble from bash, I
see them just fine using the same path. I don't know if that is why gdb
is not starting or not.
I am running out of ideas and I am getting very frustrated with this
entire setup. I thought that by installing the environment from Olimex's
CD I would avoid this exact scenario of fighting with the tools for two
days now. If it wasn't for the fact that I know I can't get another
toolchain past management due to $$$, I think I would consider it right
now.
If anyone would be kind enough to suggest something, I would very much
appreciate it!
Regards
Author: Michael Fischer (mifi)
Hello Tharon,
In this case you should have a new version like 717 from
2008-06-19 and not a version from 2007-09-05 !
It looks that you have not uninstall the old OpenOCD
and the old one is in your path before the new one or
something else.
Why do you work with two compilers, Olimex WinARM for Dummies
and YAGARTO ?
Best regards,
Michael
Michael Fischer wrote:
> Hello Tharon,
> something else.
> and YAGARTO ?
> Best regards,
> Michael
Michael,
Thank you for taking the time to respond and noting the discrepancy. I
wish that was the answer. The output I gave was collected before I
switched my tools over to yagarto. The output was exactly the same,
other than the date field, so I didn't bother to change it.
To clarify, I started by doing the Olimex install. When I couldn't even
compile, I began fixing bad path references and issues in various make
files. I then referend the SAM7 Eclipse tools tutorial that is available
on the net, which set me down the yagarto path. I have since moved over
everything to yagarto.
Right now the issue appears to be with arm-elf-gdb. There is probably
some magic tweak that will make it work, but I am at a loss what it
would be.
I think I would have been better off by not installing from the Olimex
CD. It does not run out of the box like you would expect and it has no
wizard to help you configure it for your system. If it happens to
magically work, great, but if not, you have to figure out for yourself
how to fix it. If I had followed the tutorial from start to finish, I
would have had a much better handle on what I had installed and would
have tried to configure correctly as I went. If things didn't work, I
would have a much better idea of how to fix it.
Giving up is not an option, so I will keep plugging away at it. I can
definitely say I have learned much more than if the Olimex install had
worked the first time.
Regards!
> Best regards,
> Michael
PS - I went back to the Jim Lynch tutorial and realized you are "Mr.
Yagarto". Thanks for all the work you have put into bringing it all
together. I am not sure we go far enough to thank folks that support
open source tools.
To review:
1. Initially installed Olimex's all-in-one toolchain
2. Project demo from FreeRTOS
3. Installed yagarto and have since reconfigured for that toolchain
I have to confess that I did not initially realize the Olimex toolchain
was based on WinAVR.
For what it is worth, I am going back to studying the fine print of Mr.
Lynch's tutorial. It may be a problem with my kludged configuration.
I did copy over some lines from the armusbocd.cfg into the .cfg file
that came with the FreeRTOS demo and it did clean up an error on
OpenOCD, but gdb is still not quite there. I considered that yagarto was
intended run native and not under Cygwin, so I went ahead and run it
under Zylin native (as opposed to Zylin cygwin), with everything else
being the same. I got rid of the file warnings, but it otherwise acts
exactly the same. It still has an error and suspends, but with no
indication what the issue is.
An observation: Even though .gdbinit is the default init file in various
projects for (arm-elf-)gdb, not one project actually includes a .gdbinit
file.
Best Regards!
