Forum: ARM programming with GCC/GNU tools OOCD with the STM32F103
von Lain I. (lain_iwakura)
Good day every one!
I'm using the STM32F103 series in an embedded application, together with
OOCD.
Now the 1st setup:
STM32 Evalboard by KEIL with the STM32 in a 64 Pinout and 64 K Flash
(STM32F103R8T6)
Amontec-JTAG-Key
OOCD r423 and r717
Worked just great :-)
The 2nd setup:
STM32 now in my embedded app. and with 48 pinout 64 k flash
(STM32F103C8T6)
Amontec-JTAG-Key
OOCD r423 and r717
Didn't work! :-(
Well it did work sort of, that is, OOCD finds the two JTAG-Devices
inside the µC and than 'hangs':
The output of OOCD with debug = 3:
Debug:   8 0 command.c:432 command_run_line(): telnet_port 4444
Debug:   10 0 command.c:432 command_run_line(): gdb_port 3333
Debug:   12 0 command.c:432 command_run_line(): interface ft2232
Debug:   14 0 command.c:432 command_run_line(): ft2232_device_desc
"Amontec JTAGkey A"
Debug:   16 0 command.c:432 command_run_line(): ft2232_layout jtagkey
Debug:   18 0 command.c:432 command_run_line(): jtag_speed 9
Debug:   19 0 jtag.c:1863 handle_jtag_speed_command(): handle jtag speed
Info:    20 0 options.c:50 configuration_output_handler(): jtag_speed:
9, 9
Debug:   22 0 command.c:432 command_run_line(): jtag_nsrst_delay 500
Debug:   24 0 command.c:432 command_run_line(): jtag_ntrst_delay 500
Debug:   26 0 command.c:432 command_run_line(): reset_config trst_only
Debug:   28 0 command.c:432 command_run_line(): jtag_device 4 0x1 0xf
0xe
Debug:   30 0 command.c:432 command_run_line(): jtag_device 5 0x1 0x1
0x1e
Debug:   32 0 command.c:432 command_run_line(): daemon_startup attach
Info:    33 0 options.c:50 configuration_output_handler(): Open On-Chip
Debugger (2008-06-19 19:00) svn: 717
Debug:   35 0 command.c:432 command_run_line(): target cortex_m3 little
run_and_halt 0
Debug:   37 0 command.c:432 command_run_line(): run_and_halt_time 0 30
Debug:   39 0 command.c:432 command_run_line(): working_area 0
0x20000000 0x4000 nobackup
Debug:   41 0 command.c:432 command_run_line(): flash bank stm32x
0x08000000 0x10000 0 0 0
Debug:   43 0 command.c:432 command_run_line(): gdb_memory_map enable
Debug:   45 0 command.c:432 command_run_line(): init
Debug:   46 0 openocd.c:102 handle_init_command(): target init complete
Debug:   47 0 ft2232.c:1374 ft2232_init_ftd2xx(): 'ft2232' interface
using FTD2XX with 'jtagkey' layout (0403:6010)
Debug:   48 30 ft2232.c:1463 ft2232_init_ftd2xx(): current latency
timer: 2
Debug:   49 40 ft2232.c:1729 jtagkey_init(): 80 08 1b
Debug:   50 40 ft2232.c:1787 jtagkey_init(): 82 09 0f
Debug:   51 40 ft2232.c:253 ft2232_speed(): 86 09 00
Debug:   52 50 openocd.c:109 handle_init_command(): jtag interface init
complete
Debug:   53 50 jtag.c:1537 jtag_init_inner(): Init JTAG chain
Debug:   54 50 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
controller reset (TLR or TRST)
Debug:   55 50 jtag.c:1295 jtag_reset_callback(): -
Debug:   56 50 jtag.c:1295 jtag_reset_callback(): -
Debug:   57 50 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   58 50 jtag.c:1295 jtag_reset_callback(): -
Debug:   59 50 jtag.c:1295 jtag_reset_callback(): -
Info:    60 60 jtag.c:1389 jtag_examine_chain(): JTAG device found:
0x3ba00477 (Manufacturer: 0x23b, Part: 0xba00, Version: 0x3)
Info:    61 60 jtag.c:1389 jtag_examine_chain(): JTAG device found:
0x16410041 (Manufacturer: 0x020, Part: 0x6410, Version: 0x1)
Debug:   62 60 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   63 60 jtag.c:1295 jtag_reset_callback(): -
Debug:   64 60 jtag.c:1295 jtag_reset_callback(): -
Debug:   65 60 openocd.c:116 handle_init_command(): jtag init complete
Debug:   66 60 cortex_swjdp.c:946 ahbap_debugport_init():
Debug:   67 60 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   68 80 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   69 90 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   70 100 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   71 110 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   72 120 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   73 130 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   74 140 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   75 150 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   76 160 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Debug:   77 170 cortex_swjdp.c:208 swjdp_transaction_endcheck(): swjdp:
CTRL/STAT error 0x20
Debug:   78 170 cortex_swjdp.c:946 ahbap_debugport_init():
Debug:   79 170 cortex_swjdp.c:965 ahbap_debugport_init(): swjdp: wait
CDBGPWRUPACK
Both versions of OOCD did the same.
I looked up the source code @ 'cortex_swjdp.c:965' and checked for
'CDBGPWRUPACK': that is about 'waiting for the debug port to power up'
or something like that. Checking the STM32 manual I found out that
there's only one (I hope I got that right) way to shut down the debug
port: the lowest sleep mode (I think is called DEEPSLEEP or so). Though
I cannot imagine how that mode may have been activated, because the µC
was factory fresh, I read that to re-activate the chip you can either
pull NRESET or the WAKEUP_PIN, I did both and nothing changed (I did so
while he was reporting the above and another time before connecting the
JTAG adapter).
But wait the scary stuff:
I connected the uLink me JTAG adapter, that came with the evalboard, to
my embedded app. and used µVision 3 to upload a program. This reported
success!!! but it didn't seam to run correctly on the chip (i did the
led toggle stuff, and couldn't see any output on that pin, using a DSO).
After that I connected the JTAG-Key again and with like the 10th try it
suddenly worked! I was able to program the chip, read the flash back and
erase it one time. After that I couldn't get it to work again, but
µVision still says that it is able to program the flash. Though trying
to debug on chip crashes the µVision or gives useless results.
By the way, if I try to 'JTAG' the evalboard after the above, everything
works just fine, meaning, that the JTAGkey should still be ok.
I thought of 'bad contact on some of the jtag pins' but OOCD is able to
find the two JTAG devices every time.
May be the µC is damaged or something???
HELP :-)!
Following the config for OOCD r717:
debug_level 3
#log_output "c:\oocd_r717_err.log"
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc "Amontec JTAGkey A"
jtag_speed 9
#use combined on interfaces or targets that can’t set TRST/SRST
separately
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
jtag_device 5 0x1 0x1 0x1e
#target configuration
#target <type> <startup mode>
#target cortex_m3 <endianness> <reset mode> <chainpos> <variant>
target cortex_m3 little run_and_halt 0
working_area 0 0x20000000 0x4000 nobackup
#flash bank <driver> <base> <size> <chip_width> <bus_width>
flash bank stm32x 0x08000000 0x10000 0 0 0
#debug
I got it! The Chip was broken.
I used another one in the same configuration and it did work perfectly.
cYa all.
