Forum: ARM programming with GCC/GNU tools STR9 - how to mutex in thumb mode?
Author: Dan Miller (gorlash)
I'm porting some existing (running) code from IAR to GnuArm (Yagarto).
The existing project has some shared data that it protected by using
enable/disable IRQs for mutual exclusion.  Unfortunately, the functions
that IAR used to enable/disable interrupts were intrinsic functions
(get_cpsr/set_cpsr).  When I try to convert these functions to explicit
code, I have troubles switching to/from thumb mode.  I'm still finding
the discussions of this process very confusing!!
In any case, we really should be using a true mutex method for this,
rather than mucking with interrupts (since our project has numerous
interrupt sources), but I haven't found any sources yet that describe a
thumb mode mutex mechanism.
Has anyone ever managed this??  Could you give some hints??  Or, better
still, a working example?
Author: Spencer Oliver (ntfreak)
other than using a rtos you probably do not have much choice about
disabling ints - the rtos will probably do that as well.
This is similar code from FreeRTOS for disabling ints.
void vPortDisableInterruptsFromThumb( void ) _attribute_ ((naked));
void vPortEnableInterruptsFromThumb( void ) _attribute_ ((naked));
  asm volatile (
    "STMDB  SP!, {R0}    \n\t"  /* Push R0. */
    "MRS  R0, CPSR    \n\t"  /* Get CPSR. */
    "ORR  R0, R0, #0xC0  \n\t"  /* Disable IRQ, FIQ. */
    "MSR  CPSR, R0     \n\t"  /* Write back modified value. */
    "LDMIA  SP!, {R0}     \n\t"  /* Pop R0. */
    "BX  R14" );            /*Return back to thumb. */
  asm volatile (
    "BIC  R0, R0, #0xC0  \n\t"  /* Enable IRQ, FIQ. */
    "BX  R14" );            /* Return back to thumb. */
Cheers
Spen
Okay, let me try this out.  Thanks!!
BTW, we are using no RTOS here, just startup.s calling main.c
