Forum: ARM programming with GCC/GNU tools STR9 ld-file anomalies
von Dan M. (gorlash)
Okay, I've gone back to building with gcc calling ld, vs calling ld
directly.
I'm using Yagarto 20080408.
If I have this in SECTIONS:
    /* the program code is stored in the .text section, which goes to
Flash */
    .text :
       . = ALIGN(4);
        *(.text)                   /* remaining code */
        *(.text.*)                 /* remaining code */
        *(.rodata)                 /* read-only data (constants) */
        *(.rodata*)
        *(.glue_7)
        *(.glue_7t)
       . = ALIGN(4);
       _etext = .;
       /* This is used by the startup in order to initialize the .data
secion */
    } >FLASH
    /* .data section which is used for initialized data */
secion */
    _sidata = .;
    .data : AT (_sidata)
       . = ALIGN(4);
secion */
        _sdata = . ;
        *(.data)
        *(.data.*)
       . = ALIGN(4);
secion */
       _edata = . ;
    } >DATA
My build fails:
c:/yagarto/bin/arm-elf-gcc -Todu-gnuarm.ld -Wall -I. -Iinclude
-gdwarf-2 -MD -DGNUARM -mcpu=arm9e -std=c99 -mlittle-endian -Os -g
-Wl,-Map=odu.map,--cref,--no-warn-mismatch,-static startup/91x_initga.o
main.o 91x_it.o feprom.o atmel_flash_memory.o Internal_flash_memory.o
source/91x_adc.o source/91x_caps.o source/91x_gpio.o source/91x_lib.o
source/91x_rtc.o source/91x_uart.o source/91x_vic.o source/91x_wdg.o
source/91x_fmi.o source/91x_scu.o source/91x_emi.o source/91x_dma.o  -o
odu.elf
c:/yagarto/bin/../lib/gcc/arm-elf/4.2.2/../../../../arm-elf/bin/ld.exe:
section .data [0002cf48 -> 0002db77] overlaps section .init [0002cf48 ->
0002cf67]
section .fini [0002cf68 -> 0002cf83] overlaps section .data [0002cf48 ->
0002db77]
make: *** [odu.elf] Error 1
However, if I change it to
   .data : /* collect all initialized .data sections that go into RAM
It builds successfully!!
So what's the difference??  Does omitting the "AT (location)" statement
actually put the data somewhere else??  I don't understand why that
would be the case.  What is actually being done with the data in each
case, and how do the two statements differ??
von Spencer O. (ntfreak)
> directly.
Not sure what is causing your problem.
Find attached one of my linker scripts, works with arm-elf and arm-eabi
compilers.
Cheers
Spen
