Forum: ARM programming with GCC/GNU tools Yagarto - crash in objdump (well, almost)
von Dan M. (gorlash)
After the discussions that I had in previous messages here (about
different GnuArm  versions), I tried installing Yagarto (gcc 4.2.2) and
building my project with that.  The compiling and linking went
successfully, but the last step in my makefile is to generate a listfile
with:
arm-elf-objdump.exe -h -S odu.elf > odu.lst
With GnuArm (gcc 4.1.1) objdump, this process takes about 5 seconds to
finish, with a 731KB .elf file (generated by Yagarto).  The .lst file
size is 2.7 MBytes.
With Yagarto objdump run against the same .elf file, I thought objdump
had hung, with cpu utilization stuck at 100% (on an Athlon 64 2200+ and
2.5 GB RAM).  However, eventually after a little over 2 minutes, it
did finish, having generated 1.9 MByte .lst file (much smaller than
what GnuArm output).  This looks like a bug in objdump ??
I'm holding off on attaching any files, until someone indicates what
would be useful to them.  All these files are pretty large...
Also, I notice that Yagarto did not include the C/ASM source code in
the listing, as GnuArm did.  This makes comparison of the lst files
someone difficult.
> someone difficult.
This may be caused by a bug in objdump when source-code with DOS
file-endings (\r\n) should be "intermixed" with the assembly. I have
reported the bug and submitted a fix to the binutils-project. Issue
should be fixed in the next binutils-release an binaries based on this
code. Possible solutions:
- convert you source-code to unix line-endings (\n only)
- replace objdump.exe with one compiled from older binutils sources
- compile your own objdump.exe from current binutils CVS code
- try with objdump.exe from WinARM-testing 3/2008
The increase in runtime may be caused by the "source-file-caching"
introduced in newer versions of the binutils objdump but so far I have
not seen such a huge increase in runtime.
EDIT: it may be cause by the DOS-lineending error too since the
buggy-objdump tries to read the source-code over and over again and
fails. The "possible solutions" mentioned above should fix this too
since objdump can read every souce-file just once successfully.
Ahhh!!  indeed, I ran dos2unix against all .c and .s files, and both of
these problems went away... that's a fine solution for me, for now.
Thanks!!
