Forum: ARM programming with GCC/GNU tools accees constant defined in linker script
Author: Roman Mashak (romez777)
Hello,
I define a constant in the linker script and want access it from C-code:
SECTIONS
 _bootsize = 0x00004000;
Here is code snippet:
extern unsigned long _bootsize;
char message[10];
siprintf(message, "Bootsize: 0x%x\n\r", _bootsize);
AT91F_DBGU_Frame(message);
But it always prints out "Bootsize: 0x2004d4" Why so?
As far as I understand, it's quite possible to do what I want.
Author: Giovanni Di sirio (gdisirio)
Roman Mashak wrote:
> Hello,
> SECTIONS
> char message[10];
Looking at the documentation here:
http://sourceware.org/binutils/docs-2.18/ld/Source...
If I understood it right _bootsize is the address of your constant, the
constant is allocated there as a word.
Author: Jonathan Dumaresq (dumarjo)
Roman Mashak wrote:
> Hello,
> SECTIONS
> char message[10];
Look at a sample here with the file syscall.c, you will have a sample on
how to access a constant address from C source.
Jonathan
Hm.. After reading documentation at the link, I come to the conclusion
that there is no way to assign a value to a linker script defined
symbol. Such symbol will always hold only address.
Am I right, there is no way to get what I want?
Before posting I studied that code and did as in there. It seems I can't
achieve what I need: to define a constant value in a linker script and
use it from the C code.
I must have read the link thoughtlessly the first time and missed the
point. Now I got it right - accessing the symbol defined in linker
script as "&_bootsize" works fine for me.
Thanks again.
