Forum: ARM programming with GCC/GNU tools At91Sam7s g++ generates huge code
von Michał W. (michwolo)
Hello Everybody.
I have problem with huge code whitch generates by arm-elf-g++. I red
post in this forum but my case is other. I can't use options CXXFLAGS
+=-nostdlib because i use #include<vector> and operator new in my class
and code etc. I wrote simple program and everything work properly
without large code, a simple blinking led - code have 71kb nightmare. I
use syscalls.c and ofcourse reduce code about 2 kb, mayby i should write
more definitions. Please help me. In attachment I include syscalls.c
(this file isn't my). Bestregards Michal Wolo
von Jonathan D. (dumarjo)
Michał Wolo wrote:
> Hello Everybody.
you can try to disable the exception if you don't need it. it will
reduce the code.
But for the rest, I really don't know.
Jonathan
von Giovanni D. (gdisirio)
Michał Wolo wrote:
> Hello Everybody.
Hello, I wrote a G++ demo for the LPC2148 that just takes 3 or 4 KB, you
need to specify -fno-rtti as option, this saves a LOT of space (of
course if you don't need RTTI).
If you want to look at the demo code, try here:
http://sourceforge.net/projects/chibios/
Download the zip file and look into the directory
./demos/ARM7-LPC214x-G++
Giovanni
von Clifford S. (clifford)
Michał Wolo wrote:
> Hello Everybody.
The use of STL code alone will increase size significantly - STL
contains a lot of functionality, but you don't get something for
nothing.
You also have to realise the manner in which templates work and are
implemented in GNU.
In C++ in general, for each data type you instantiate a template for,
the compiler generates unique code for that type. So for example if you
create vectors for 5 different types, you will get five implementations
of what may be almost identical code. This can quickly lead to
code-bloat. You can create as many vectors for one type as you wish, but
you get one template instantiation for each type.
Further more, unless the linker is 'template aware' (and it is not), if
you create say a vector<int> in one module, and then a vector<int> in
another, you will get two copies of vector<int>. This is because only
the compiler can instantiate a template, and the compiler deals with
single modules. This is also the reason that the template code is
inlined in the header file. For this not to be so, the compiler would
have to embed the template source into the object file, and then the
linker on encountering a matching template would have to pass the
template source back to the compiler to instantiate it. That way all
modules could share a single instantiated template. This feature is
'promised' for some future version of GCC/LD.
In the end I would suggest that STL is just not suited to resource
constrained targets. And this probably applies to templates in general
if you are not careful. You can minimise the code size by minimising the
number of types you instantiate a template for, and by ensuring that all
instantiations of a particular type are in the same compilation unit.
Note that the EC++ 'standard', although now largely outdated and
ignored, does not allow templates at all;
http://en.wikipedia.org/wiki/Embedded_C%2B%2B. Of all the parts of C++
removed to form EC++ only the avoidance of templates, exceptions, and
rtti has any real merit in my opinion, and you don't need a specific
EC++ compiler to do that.
Clifford
