Forum: ARM programming with GCC/GNU tools gdb gets no communication with BDI2000
von Robert B. (roe)
Hi
I am rather new with the ARM-processor and and all these tools. I am
using the following hardware and tools:
Target: AT91SAM7X-EK Evaluation Board of ATMEL
Tools:  Yagarto gcc-based GNU-Toolchain (native windows) running under
Eclipse Europe IDE (V 3.3.1.1)
BDI2000:(by Abatron), configured for ARM using B20ARMGD.EXE V1.05
My system compiles and links projects that I created from
example-projects provided by ATMEL. I can modify the source, compile and
link it and download the code to either flash or RAM using SAM-BA. The
flash-version works as I can see from the blinking LEDs on the board
(following a power up), but I do not know how to launch the program
loaded into RAM. That is probably where the Debugger would come in. I
have configured the debugger as shown in the attachment.
The IP-Adress specified is ok - the BDI2000 answers when pinged. The
port 2001 is according to the BDI-Manual. So it should work. but it does
not. The consol-output of the gdb reports the following (exerpt
follows):
29-gdb-show prompt
29^done,value="(gdb) "
(gdb)
30-gdb-set new-console on
&"No symbol \"new\" in current context.\n"
30^error,msg="No symbol \"new\" in current context."
(gdb)
31-target-select remote 192.168.0.21:2001
No symbol "new" in current context.
&"192.168.0.21:2001: Es konnte keine Verbindung hergestellt werden, da
der Zielcomputer die Verbindung verweigerte.\n"
31^error,msg="192.168.0.21:2001: Es konnte keine Verbindung hergestellt
werden, da der Zielcomputer die Verbindung verweigerte."
(gdb)
32
192.168.0.21:2001: Es konnte keine Verbindung hergestellt werden, da der
&"\n"
32^done
(gdb)
33-environment-directory C:/ProjDAc/ws1/My2 C:/ProjDAc/ws1/My2/.settings
C:/ProjDAc/ws1/My2/Debug C:/ProjDAc/ws1/My2/bin C:/ProjDAc/ws1/My2/obj
33^done,source-path="C:/ProjDAc/ws1/My2;C:/ProjDAc/ws1/My2/.settings;C:/
ProjDAc/ws1/My2/Debug;C:/ProjDAc/ws1/My2/bin;C:/ProjDAc/ws1/My2/obj;$cdi
r;$cwd"
(gdb)
34 info threads
Hence no connection with the BDI. What's wrong?
Thanks and best regards
Robert
