Forum: ARM programming with GCC/GNU tools help..urgent..
von Tiong L. (ctloh)
Hi all,this is the main program of my project to read time from server
and show on lcd panel.can anyone help me on what command should i add to
read the reading from ADC (i give a voltage by using potentialmeter) and
display on lcd?
#include <stdlib.h>   /* For system(). */
#include <stdio.h>    /* For printf(). */
#undef HTONS
#include "cs8900a.h"
#include "uip.h"
#include "uip_arp.h"
#include "webclient.h"
#include "lcd.h"
#include "lpc21xx.h"
static const struct uip_eth_addr ethaddr =
{{0x00,0x00,0xe2,0x58,0xb6,0x6b}};
#define BUF ((struct uip_eth_hdr *)&uip_buf[0])
#ifndef NULL
#define NULL (void *)0
#endif /* NULL */
static unsigned short start, current;
#define RT_CLOCK_SECOND 2048
 * \internal
 * A real-time clock.
 * This example main() function uses polling of a real-time clock in
 * order to know when the periodic processing should be
 * performed. This is implemented using this function - rt_ticks(). In
 * this example unix implementation, it simply calls the unix function
 * gettimeofday() which returns the current wall clock time.
 * For a micro-controller, a simple way to implement this function is
 * by having a counter that is incremented by a timer interrupt and
 * read by this function.
 * The macro RT_CLOCK_SECOND should be defined as the approximate
 * number of ticks that are elapsed during one second.
extern unsigned short rt_ticks(void);
u8_t setTMP;
int update_time;
char s[8], rev_data[8];
struct tTimestamp {
  u8_t  h;
  u8_t  mi;
  u8_t  s;
static void SysInit(void)
  // set PLL multiplier & divisor.
  // values computed from config.h
  PLLCFG = (4-1)|(1<<5)|(0<<5);
  // enable PLL
  PLLCON = 1;
  PLLFEED = 0xAA;                       // Make it happen.  These two
updates
  PLLFEED = 0x55;                       // MUST occur in sequence.
  // wait for PLL lock
  while (!(PLLSTAT & (1<<10)))
  continue;
  // enable & connect PLL
  PLLCON = (1<<0)|(1<<1);
updates
  // setup & enable the MAM
  MAMCR = 0;
  MAMTIM = ((14745000*4) + 19999999) / 20000000;
  MAMCR = 2;
  // set the peripheral bus speed
  // value computed from config.h
  VPBDIV = (2 & 0x03);                // set the peripheral bus clock
speed
  // set the interrupt controller defaults
  #if defined(RAM_RUN)
  MEMMAP = (1<<1);                 // map interrupt vectors space into
SRAM
  #elif defined(ROM_RUN)
  MEMMAP = (1<<0);                // map interrupt vectors space into
FLASH
  #else
  #error RUN_MODE not defined!
  #endif
void init_rtc(void)
{  int myPREINT=((((14745000*4)/2)/32768)-1);
   int myPREFRAC=(((14745000*4)/2)-((myPREINT+1)*32768));
   ILR = 0x3;     // Disable 32'768 interrupt
   PREINT = myPREINT;
   PREFRAC = myPREFRAC;
   set_time();
   CCR = 0x11;    /* disabale CTC-Reset and enable clock with CLKEN */
void set_time(void)
{  int tmphrs[2], tmpmin[2], tmpsec[2];
   CCR = 0x10;
   tmphrs[0] =(rev_data[0] & 0x0f);
   tmphrs[1] =(rev_data[1] & 0x0f);
   HOUR = (tmphrs[0]*10 + tmphrs[1]);  // Hours
   tmpmin[0] =(rev_data[3] & 0x0f);
   tmpmin[1] =(rev_data[4] & 0x0f);
   MIN = (tmpmin[0]*10 + tmpmin[1]);  // Minutes
   tmpsec[0] =(rev_data[6] & 0x0f);
   tmpsec[1] =(rev_data[7] & 0x0f);
   SEC = (tmpsec[0]*10 + tmpsec[1]);  // Seconds
   CCR = 0x01;
void RTC_GetTime(struct tTimestamp *ts)
  ts->s  = (u8_t)SEC;
  ts->mi = (u8_t)MIN;
  ts->h  = (u8_t)HOUR;
int
main(void)
{ struct tTimestamp ts;
  u8_t i, arptimer, num_display;
  setTMP=10;
  SysInit();
  /* Initialize the uIP TCP/IP stack. */
  uip_init();
  uip_arp_init();
  /* Register the Ethernet MAC address with uIP. In reality, the MAC
     address should be obtained from the EEPROM of the network
     hardware before calling this function. */
//  uip_setethaddr(ethaddr);
  /* Setup the IP address and netmask. */
//  uip_ipaddr(addr, 192,168,0,30);
//  uip_sethostaddr(addr);
//  uip_ipaddr(addr, 255,255,255,0);
//  uip_setnetmask(addr);
  /* Configure the IP address of the default router. */
//  uip_ipaddr(addr, 192,168,0,1);
//  uip_setdraddr(addr);
  /* Initialize the device driver. */
  cs8900a_init();
  /* Initialize the HTTP client. */
  webclient_init(setTMP);
  start = rt_ticks();
  arptimer = 0;
  while(1) {
  update_time=0;
  num_display=100;
    /* Let the tapdev network device driver read an entire IP packet
       into the uip_buf. If it returns > 0, there is a packet in the
       uip_buf buffer. */
    uip_len = cs8900a_poll();
    if(uip_len > 0) {
      /* A packet is present in the packet buffer. We call the
   appropriate ARP functions depending on what kind of packet we
   have received. If the packet is an IP packet, we should call
   uip_input() as well. */
      if(BUF->type == htons(UIP_ETHTYPE_IP)) {
  uip_arp_ipin();
  uip_input();
  /* If the above function invocation resulted in data that
     should be sent out on the network, the global variable
     uip_len is set to a value > 0. */
  if(uip_len > 0) {
    uip_arp_out();
    cs8900a_send();
      } else if(BUF->type == htons(UIP_ETHTYPE_ARP)) {
  uip_arp_arpin();
  if(uip_len > 0) {
    cs8900a_send();
    } else {
      /* The poll function returned 0, so no packet was
   received. Instead we check if there is time that we do the
   periodic processing. */
      current = rt_ticks();
      if((u16_t)(current - start) >= (u16_t)RT_CLOCK_SECOND / 2) {
  start = current;
  for(i = 0; i < UIP_CONNS; i++) {
    uip_periodic(i);
    if(uip_len > 0) {
      uip_arp_out();
      cs8900a_send();
#if UIP_UDP
  for(i = 0; i < UIP_UDP_CONNS; i++) {
    uip_udp_periodic(i);
    if(uip_len > 0) {
      uip_arp_out();
      cs8900a_send();
#endif /* UIP_UDP */
  /* Call the ARP timer function every 10 seconds. */
  if(++arptimer == 20) {
    uip_arp_timer();
    arptimer = 0;
  if (update_time == 1)
  {  init_rtc();
    lcd_init();
    do
    Display();
    num_display--;
    }while(num_display);
  if(num_display==0)
  {setTMP++;
  webclient_init(setTMP);}
  return 0;
/*void
uip_log(char *m)
  // printf("uIP log message: %s\n", m);
void
resolv_found(char *name, u16_t *ipaddr)
  u16_t *ipaddr2;
  if(ipaddr == NULL) {
  lcd_init();
  lcd_cursor_off();
  lcd_cursor_home();
  lcd_clear();
    lcd_print("Host not found");
  } else {
  lcd_init();
    lcd_cursor_off();
  lcd_cursor_home();
  lcd_clear();
    lcd_print("Found name");
void
webclient_closed(void)
  lcd_init();
  lcd_cursor_off();
  lcd_cursor_home();
  lcd_clear();
    lcd_print("closed");
void
webclient_aborted(void)
  lcd_init();
  lcd_cursor_off();
  lcd_cursor_home();
  lcd_clear();
    lcd_print("Connection aborted");
  delay();
void
webclient_timedout(void)
  lcd_init();
  lcd_cursor_off();
  lcd_cursor_home();
  lcd_clear();
    lcd_print("time out");
void
webclient_connected(void)
  lcd_init();
    lcd_cursor_off();
  lcd_cursor_home();
  lcd_clear();
    lcd_print("waiting");
  delay();
void
webclient_datahandler(char *data, u16_t len)
  rev_data[0] = *(data);
  rev_data[1] = *(data + 1);
  rev_data[2] = *(data + 2);
  rev_data[3] = *(data + 3);
  rev_data[4] = *(data + 4);
  rev_data[5] = *(data + 5);
  rev_data[6] = *(data + 6);
  rev_data[7] = *(data + 7);
  update_time = 1;
void Display(void)
  RTC_GetTime(&ts);
  s[0]=ts.h/10+'0';
  s[1]=ts.h%10+'0';
  s[2]=':';
  s[3]=ts.mi/10+'0';
  s[4]=ts.mi%10+'0';
  s[5]=':';
  s[6]=ts.s/10+'0';
  s[7]=ts.s%10+'0';
  delay();
  delay();
  lcd_cursor_off();
  delay();
  delay();
  //lcd_clear();
  //delay();
  //delay();
  lcd_cursor_home();
  delay();
  delay();
  lcd_putchar(s[0]);
  delay();
  lcd_putchar(s[1]);
  delay();
  lcd_putchar(s[2]);
  delay();
  lcd_putchar(s[3]);
  delay();
  lcd_putchar(s[4]);
  delay();
  lcd_putchar(s[5]);
  delay();
  lcd_putchar(s[6]);
  delay();
  lcd_putchar(s[7]);
  delay();
  delay();
von Jim K. (ancaritha)
Which processor are you using?
Try looking in the WinArm examples folder.  There is an lpc2129 example
that uses the ADCs.  If you are using a SAM7 series processor, check the
Atmel site for example code.
Hi Jim Kaz,
i am using Olimex LPC-E2129.I had download the the examples from WinARM
examples folder.But i dun know how to integrate the code in my main
program.can you help me on that?i wan to display the value from adc at
the lcd panel.(I supply a voltage to P0.27 by using potentiometer).hope
to hear from u soon...Thanks.
Tiong Loh wrote:
> Hi Jim Kaz,
I'm pretty busy with a bunch of work stuff right now, so I may be able
to help you, but its not going to be in a timely manner.  You're best
off trying to figure it out for yourself.  I've also never looked at
code for the LPC, so I'm not sure how long it would take me to get up to
speed on what all the different registers do and how they interact, and
I probably don't have that time available.
