Forum: ARM programming with GCC/GNU tools WinARM, Yagarto & Eclipse issues
von Bruce P. (abruceperson)
I've sent these questions to the lpc2000 yahoo list recently, but
perhaps this is the more appropriate forum.
They both relate to my recent attempt to upgrade from WinARM (containing
arm-elf-gcc 4.0.0) to a more recent version.
Issue 1: Eclipse compile crash
A simple make to do an intermediate compile (.c->.o) fails where it used
to work with fine the older environment.
The error I get is:
make -k all
adc.c
rm -f adc.o
arm-elf-gcc -c -mcpu=arm7tdmi-s -I. -ggdb2  -isystem "../../newlib5.1"
-isystem "C:/WinARM/arm-elf/include" -isystem
"../../newlib5.1/rdcf2/include" -O0 -fsigned-char -funsigned-bitfields
-fshort-enums -ftabstop=4 -fpack-struct -mstructure-size-boundary=32
-msingle-pic-base -Wall -Wstrict-prototypes -Wno-format-extra-args
-Wno-format-zero-length -Werror-implicit-function-declaration
-Wa,-adhlns=adc.lst -Wpadded -I..\include -MD -MP -MF .dep/adc.o.d adc.c
-o adc.o
This application has requested the Runtime to terminate it in an unusual
way.
Please contact the application's support team for more information.
make: *** [adc.o] Error 3
make: Target `all' not remade because of errors.
This occurs for both WinARM 4.1.2 and for Yagarto 4.2.1 (latest of each)
providing the arm-elf-gcc exe above. "make.exe" can be either WinARM
utils version.
I did this by changing PATH in the C/C++ Make Project->Environment in
Eclipse.
If I type "make all" in a DOS prompt, with the appropriate PATH set as
above, it works fine in all cases. It only bombs if done through
Eclipse.
Based on Google seaching, I thought it may have something to do with
heap size available to Eclipse, so I tried increasing this in
eclipse.ini. No help.
I also tried upgrading the Eclipse I was running from 3.2.0 to 3.3.0
from the latest Yagarto-IDE download, but exactly the same error.
Issue 2: libc difference between WinARM and Yagarto.
I had problems in the exceutable when created with Yagarto 4.2.1. The
problems do not occur with WinARM 4.1.2. As far as I can tell, by
looking at the map and lss files output, though both distros are newlib
based, only WinARM is newlib_lpc compatible.
If I follow the calling sequence of say "open()" for Yagarto:
open()->_open -> _swiopen() which cases a undesirted SWI (reset in my
case)
newlib_lpc by contrast provides the stub _open_r, which is replaced in
WinARM but ignored by Yagarto. Perhaps Yagarto hasn't been compiled with
the compile switch -DREENTRANT_SYSCALLS_PROVIDED as recommended by Bill
Gattliff ?
http://venus.billgatliff.com/node/3
Issue 3: whence libg.a ?
It seems libg.a is libc.a with debugging information included. Why, if I
only ever specify -lc to the link phase (not -lg) do I still get items
in my map file included from libg.a ?  Is this perhaps implied when you
specfiy other debug options along with -lc ?  More a curiousity than a
real problem as it seems libg and libc are identical on WinARM and
Yagarto.
Cheers,
Bruce
Sorry, I don't use Eclipse that often an so far I have not seen this
issue. So I currently can not help with this one.
> case)
It seems that the standard syscalls are used with the Yagarto build.
> Gattliff ?
Yes, the newlib in WinARM is build with newlib provided syscalls
disabled and to use reentrant syscalls. I use this setup since the first
WinARM package which I created to be compatible with newlib-lpc "out of
the box" for may own experiments.
AFAIK Michael Fischer uses the "standard configuration" for newlib. As a
workaround you may remove the syscalls.o object from the used
"Yagarto"-libc.a, but this might be an ugly hack. There might be better
solutions with special linker-options and/or library grouping but so far
I had to need to investigate this (obviously I'm using WinARM).
Sorry, not quick answer from my side on this, I have not used yet used
option -lg/linked with libg.a.
Martin Thomas
von Andy B. (andybutcher)
This may be too late to help you, but I'll post here anyway since this
is the only place I've seen this problem raised, maybe it'll help
others.
I'm trying Yagarto for the first time (for Atmep AT91SAM7S), and had the
same symptoms. I noticed that "make clean" generated a bash error
'can't find /tmp' or similar.
My Eclipse environment included TMP=C:\DOCUME~1\username\LOCALS~1\Temp
(project/properties/C C++ Build/environment 'Select'), presumably picked
up from the DOS environment. Adding TMP to the Eclipse environment
variables, changing it to the full Windows path (C:\Documents and
Settings\username\Local Settings\Temp) and selecting 'Replace native
environment...' fixed the problem. Surprisingly, the spaces in the path
don't seem to break anything !
BTW, I also had problems with multiple versions of make in the search
path - including Borland's 'make' which bears no resemblance to gnu
make. The safest solution is to put an explicit PATH in Eclipse, again
with 'Replace...'.
Now I'm just waiting for our so-called purchasing department to expedite
delivery of an ARM evaluation kit...
I hope this helps, either Bruce or some other poor guy in the future.
Andy
