Forum: ARM programming with GCC/GNU tools Yagarto - OpenOCD r423 : flash write (write_binary) not work
Author: Thomas Schulte (1stern)
Hello friends,
I installed the r423 and found out that the flash command ist not
accepting further keywords like write or the newer command write_binary.
Any idea ?
Am I doing s.th. wrong?
Regards
Thomas
OpenOCD ist currently a very "moving target". Can you check if flash
write_image does work for you (i.e. flash write_image test.bin 0 bin)?
write_image ALSO MISSING. This is coming out:
Open On-Chip Debugger (2008-03-01 20:00 CET) svn: 423
$URL: http://svn.berlios.de/svnroot/repos/openocd/trunk $
Info:    options.c:50 configuration_output_handler(): Command
write_image not found
I am using the provided sam7s_jtagkey.cfg.
I added only 2 lines to it
flash write_image 0 main.bin 0x0
shutdown
# tell gdb our flash memory map
# and enable flash programming
gdb_memory_map enable
gdb_flash_program enable
#interface
interface ft2232
ft2232_device_desc "Amontec JTAGkey A"
ft2232_layout jtagkey
ft2232_vid_pid 0x0403 0xcff8
jtag_speed 0
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#use combined on interfaces or targets that can't set TRST/SRST
separately
reset_config srst_only srst_pulls_trst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target <type> <startup mode>
#target arm7tdmi <reset mode> <chainpos> <endianness> <variant>
target arm7tdmi little run_and_init 0 arm7tdmi
run_and_halt_time 0 30
target_script 0 reset
C:\Development\openocd\bin\scripts\sam7s256\sam7s_reset.script
flash write_image 0 main.bin 0x0  # program the onchip flash
working_area 0 0x00200000 0x4000 nobackup
#flash bank <driver> <base> <size> <chip_width> <bus_width>
flash bank at91sam7 0 0 0 0 0
# For more information about the configuration files, take a look at:
# http://openfacts.berlios.de/index-en.phtml?title=O...
shutdown
flash probe hat es auch erwischt %-)
Wahrscheinlich betrifft es das ganze flash ...
Übrigens, im cmd window, openocd-ftd2xx.exe -c help
erscheint für flash und eine Reihe anderer Kandidaten:
"no help available"
Vielleicht ein Hinweis?
Grußt
Thomas
Author: Michael Fischer (mifi)
Hello Thomas,
it is working here, I have checked it again with my sam7s256 target.
"flash probe 0" works, and even "flash write_image".
If you like contact me direct to solve your problem. We can
make the result here public.
Regards,
Michael
Author: Jonathan Dumaresq (dumarjo)
Thomas Schulte wrote:
> Hello friends,
> Any idea ?
> Regards
> Thomas
Same problem here with sam7x devices.
Could be great to have a solution for this. right now I use the r247 and
it's work
Jonathan
Author: Helmut Jansen (jah4711)
Michael Fischer wrote:
> Hello Thomas,
> Regards,
> Michael
Hi everybody,
I have the same problems with OpenOCD r423 and newer.
Do you have any solution or information ?
Regards,
Helmut
>> Hello Thomas,
>> Regards,
>> Michael
> Hi everybody,
yeah, look in the pdf that comes with Yagarto, you will see the new
command sets.
Jonathan
> Regards,
> Helmut
Hi Jonathan,
thanks for this answer, but the pdf comes with openocd !
I have already read the manual and changed the
"DEPRECATED" Flash wite command to flash write_binary.
The result is "command not found".
**** Build of configuration Default for project
demo_at91sam7_blink_flash ****
make -k program
Flash Programming with OpenOCD...
'C:/Programme/openocd-r520/bin/'openocd-ftd2xx.exe -f
'C:/Programme/openocd-r520/bin/'at91sam7s256-jtagkey-flash-program.cfg
# program the onchip FLASH here
Open On-Chip Debugger (2008-03-22 12:00 CET) svn: r520
URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/
Info:    jtag.c:1329 jtag_examine_chain(): JTAG device found: 0x3f0f0f0f
(Manufacturer: 0x787, Part: 0xf0f0, Version: 0x3)
Warning: jtag.c:902 jtag_add_reset(): requested reset would assert trst
Info:    target.c:240 target_init_handler(): executing reset script
'script.ocd'
Info:    options.c:50 configuration_output_handler(): core state: ARM
write_binary not found
'script.ocd'
Regards,
Helmut
> command sets.
> Jonathan
>> Regards,
>> Helmut
flash write_binary is not longer available in newer versions of Openocd
as far as I can see (not just "will be gone soon" but gone). Search the
pdf for flash write_bank which should be the "drop-in" replacement, also
see flash write_image.
In my opinion the old commands should have been kept for compatiblity as
long as possible but obviously the developers wanted to clean up the
code. So we "end-users" have to live with it.
