Forum: ARM programming with GCC/GNU tools Help to resolve some problem
Author: Sevc Dominik (sevc)
Hi all again.
I use pointer with structure and compiler show problem:
cnc1.c:76: warning: passing argument 4 of 'StartMove' discards
qualifiers from pointer target type
Program work but how can I resolve this warning???
I like if compiler donw't show any warning or error.
regards
Author: Mhel Marcelo (mhel)
I think it has something to do with const qualifier.
you can try casting the said argument...or...
you could post the code for other's to see. :)
Sevc Dominik wrote:
> Hi all again.
> regards
in file axes.h is:
typedef struct {
    float  Vactual;
    float  Vmax;
    float  Vneed;
    float  Vstart;
    float  Amax;
               }  Ax_parameter;
extern volatile Ax_parameter Ax_p_x;
extern void MoveAx(Ax_parameter *Ax_par, BYTE Ax);
in axes.c is :
volatile Ax_parameter Ax_p_x = {0,0,0,0,0};
in main.c is:
MoveAx(&Ax_p_x,0);
on this line compiler show warning .
any sugestion????
regards
> MoveAx(&Ax_p_x,0);
the above line doesn't match the warning you get
I'm positive that the warning you get is in the line
that says something "like"...
StartMove(arg1,arg2,arg3,arg4,arg...);
..just trying to help :)
Oh yes I use differ function not StartMove but MoveAx , but parameter is
same.
Warning show so 4th argument is not good definition, if use function
MoveAx then compiler show warning passing argument 1 of 'MoveAx'
discards
regards
