Forum: ARM programming with GCC/GNU tools sprintf
Author: Harold Ritter (hlritter)
I am attempting to use sprintf without success.
in main i have:
char str[80];
  sprintf(str, "sprintf test - Hex Number %02X - Decimal Number %d",
127, 0x0a);
After this line of code is run I would expect str to conatin:
  "sprintf test - Hex Number 7F - Decimal Number 10" without the quotes
ocourse.
This code does not compile. I never get to run it. Instead I get this
build error:
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\newlib\libc\sys\arm/../../
../../../../newlib-1.14.0/newlib/libc/sys/arm/syscalls.c
undefined reference to `end'
This directory does not even exist on my hard drive!
Author: Mhel Marcelo (mhel)
somewhere in this
http://forum.sparkfun.com/viewtopic.php?t=5390&pos...
has the answer.
I believed Clifford mentioned it sometime ago relating to syscalls, and
pointed to the same link.
> in main i have:
> char str[80];
> 127, 0x0a);
> ocourse.
> build error:
Mhel,
Thank you so much! Indeed the answer was there and here it is quoted
directly from Sparkfun. IT WORKS!
The end is close.
The end in this case is a symbol that points to the first free word in
RAM after all global variables has been placed there. Some codelibraries
use the symbol _end and some use the symbol end (without the
underscore). It is usually defined in the linker script, in you case
demo_at91sam7_blink_flash.cmd
At the end, after the the definition of the symbol _end, add the line
PROVIDE(end = .);
This means: let the symbol 'end' point to the current position unless it
has been given a differnt value somewhere else.
[Jim] Perhaps this should standard in the linker scripts.
Code:
       _end = .;
       PROVIDE(end = .);
So actually end is the beginning of the heap.
Regards,
Magnus
Thanks again Mhel and a special thanks to Magnus on sparkfun!
Harold
Mhel Marcelo wrote:
> somewhere in this
> has the answer.
>> in main i have:
>> char str[80];
>> 127, 0x0a);
>> ocourse.
>> build error:
