Forum: ARM programming with GCC/GNU tools AT91SAM7S.H
von Harold R. (hlritter)
I have an Atmel AT91SAM7S-EK board with the 7S256 part mounted. I also
have the tutorials from Atmel. The tutorials contain a file called
"at91sam7s.h". The definitions inside this file are actually for the
7X256 and there are differences.
For instance RXD0 is on PA5 of the 7S part but the definitiuon for it in
the H file is as follows
#define AT91C_PIO_PA0        ((unsigned int) 1 <<  0) // Pin Controlled
by PA0
#define AT91C_PA0_RXD0     ((unsigned int) AT91C_PIO_PA0) //  USART 0
Receive
This definition is correct for the 7X part but not the 7S.
The blinky demo works on my board as it is supposed to and I assume that
much of the 7X part is exactly as the 7S part but does there exist
somewhere a header file that reflects the true definitions for the 7S
part?
Thanks!
> by PA0
> Receive
> part?
The software-package
http://www.atmel.com/dyn/resources/prod_documents/softpack-1.2-at91sam7s-ek-web.zip
should include correct defintion-files. Extract one of the archives in
the package and look into the directory
at91lib/boards/at91sam7s-ek/at91sam7s*
