Forum: ARM programming with GCC/GNU tools Reset vector from the WinARM examples doesn't work
Author: Dim Alex (kobe8)
Hello,
for more than an year I've been using the WinARM compiler + OpenOCD +
Eclipse/PN + AT91SAM7S128 based board for my projects. The makefile, the
startup code and the linker script, that I’m using, are based on the
examples from the WinARM package.
Recently I’ve discovered that the HW reset button on my board doesn’t
work. Actually it works, but only after the Flash has been programmed
via the OpenOCD (using the makefile). After boot it seems that the reset
vector is no longer doing its gob. I’ve studied the spartup code
carefully and I don’t see any troubles in there.
Did somebody noticed the same problem with the examples from the WinARM,
or had the same problem?
Thanks,
Dim
sing
Which one? There are different examples with different startup-codes
included for SAM7S. Please check my web-pages too, some examples have
been updated since the latest "official" release of WinARM (20060606).
Did you verify that the hardware-reset though the reset-pin is
activated? On SAM7S this has to be done by software. Most of the
"WinARM-examples" should include this activation, but I do not remember
if it's included in all of them.
Hello Martin,
thanks for the answer.
I'm using the startup code from the 'gamma' project, but not from the
last version.
Indeed I didn't activated this option, and this was my problem.
Thanks a lot for the hint.
Best regards,
Dim
