Forum: ARM programming with GCC/GNU tools Yagarto 'new standard make C project' not available
von Jerome J. (joeman)
Hi All
I've installed all tools required to compile ARM AT91 SAM7 from Atmel,
according to the document "Using Open Source Tools for AT91SAM7S Cross
Development revision C.pdf"
I'm now trying to create a new project in Ecplipse, the document
mentions
to create a project called Yagarto 'new standard make C project', but I
cannot find this new project wizard, the only wizard I get from Eclipse
are shown in the snaphsot attached !?
Any idea why I cannot see this project wizard ?
I'm running Eclipse
Version: 3.3.1.1
Build id: M20071023-1652
Thanks to all !
von James L. (lynchzilla)
Hello Jerome.
Since publication of my Revision C of the Atmel tutorial, Eclipse has
made a major release called Europa (Ver 3.3) and there have been a few
modest changes in some of the procedures.
The creation of a project is a bit different and when you get to the
part where you enter the project name, it behooves you to click on
"Makefile Project" followed by "Other Toolchain" when it appears. This
guarantees that the makefile and the ARM tool chain will be used; not
the embedded cycwin system for the 8086 processor family.
Finally, the "Stop at Main()" checkbox is missing in the Debug
Configuration screen. This means that you must add this feature to the
GDB startup script with the following additional command:
thbreak main
added near the end of the script before the "continue" command. This
addition would be required to use the debugger.
Cheers,
JIm Lynch
Thanks for your prompt reply James !
I successfuly created and imported the led blink sample project,
regarding the GDB script, could you please let me know which file do I
need to update according to your recommendation ?
again, thanks
James Lynch wrote:
> Hello Jerome.
> thbreak main
> Cheers,
> JIm Lynch
