Forum: ARM programming with GCC/GNU tools Problems with USB HID using AT91SAM7SE512SE
von Christian W. (bluejac)
I'm trying to set up an USB Human Interface Device like discripted at
the Atmel-Site.
(http://atmel.com/dyn/products/tools_card.asp?tool_id=4092)
My problem is, that I want to use the GNU Chain Tool with "arm-elf-gcc"
and "make" for Windows. In the pdf-Readme is said, that I have to use
nmake. I have no idea how to change the example to use it with make.
I found at
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index_at91.html#at91_usb1
the "AT91 USB Core + HID Code ported to GNU/gcc"-project which I also
tried to run. With starting the building-process the message prompt:
**** Build of configuration Default for project HID ****
make all
make: *** No rule to make target `all'.  Stop.
So, in the end I spent a lot of time and have no idea how to fix the
problem.
I can't be so difficult to run a simple program for this
Microcontroller...
> I found at
> make all
Ok. This was mistake I did. Solved the one and get new one :)
I have the AT91SAM7SE512 on a AT91SAM7SE512-EK Board.
The make-command "make TARGET=AT91SAM7SE512 BOARD=AT91SAM7SE512-EK" is
followed with errors:
board.h:80:6: error: #error core_board.h Main clock
board.h:147:2: error: #error message core_board.h led
board.h:225:6: error: #error core_board.h switch
board.h:267:10: error: #error core_board.h BUS POWERED
In file included from device.c:46:
board.h: In function 'AT91F_LED_On':
board.h:298: error: 'LED_PIO' undeclared (first use in this function)
board.h:298: error: (Each undeclared identifier is reported only once
board.h:298: error: for each function it appears in.)
board.h: In function 'AT91F_LED_Off':
board.h:307: error: 'LED_PIO' undeclared (first use in this function)
board.h: In function 'AT91F_LED_Init':
board.h:315: error: 'LED_PIO_ID' undeclared (first use in this function)
board.h:316: error: 'LED_PIO' undeclared (first use in this function)
board.h:316: error: 'LED_POWER' undeclared (first use in this function)
board.h:317: error: 'LED_USB' undeclared (first use in this function)
board.h:318: error: 'LED_MEM' undeclared (first use in this function)
board.h: In function 'AT91F_LED_Toggle':
board.h:327: error: 'LED_PIO' undeclared (first use in this function)
board.h: In function 'AT91F_BUTTON_Init':
board.h:342: error: 'SWITCH_PIO_ID' undeclared (first use in this
function)
board.h:343: error: 'SWITCH_PIO' undeclared (first use in this function)
board.h:343: error: 'SWITCH1' undeclared (first use in this function)
board.h:344: error: 'SWITCH2' undeclared (first use in this function)
board.h:345: error: 'SWITCH3' undeclared (first use in this function)
board.h:346: error: 'SWITCH4' undeclared (first use in this function)
Any idea, what I have to change, to build the project without errors? I
haven't found any information for this problem.
Thanks, Christian
OOOOOOOOOOOoookaaaayyy...
The Boardname was worng in the commandline. Right way is most likely
"make TARGET=AT91SAM7SE512 BOARD=AT91SAM7SEEK MODE=MOUSE".
mthomans edit the device.h file and exact for this line I get following
error-message:
"device.c:117: error: 'struct _AT91S_MC' has no member named 'MC_FMR'"
Anybody knows for what this line is and why it don't work with
AT91SAM7SE512-Evaluation Board? And maybe how to fix this?
I searched for the file in which the struct is defined but didn't find
any result.
Thanks, Christian
What version of make do you use (output of make --version)?
make v3.81
I got external help and I get the suggestion to exchange the code-line
with the following:
AT91C_BASE_MC->MC0_FMR = AT91C_MC_FWS_1FWS;
AT91C_BASE_MC->MC1_FMR = AT91C_MC_FWS_1FWS;
After doing the exchange, the example-project worked.
If you have another solution, let me know.
Regards,
Christian
