Forum: ARM programming with GCC/GNU tools newbie questions about memory allocation
Author: Sergio d. Reyes (sdplox)
Hi everibody, thanks for reading..
im newbie with GNU-ARM and i want to compile my first project and test
it in my machine, ARM7, so i need personalize the makefile, i searched
other makefiles to learn how to do one, and after read many of them, i
found that the changes on memory allocation, "always"(in the projects
that i see, always) are here:
FIQ_STACK_SIZE = 0x0100;|
IRQ_STACK_SIZE = 0x0100;|
ABT_STACK_SIZE = 0x0100;|  <---- all of this block remains unchangeable
but i
UND_STACK_SIZE = 0x0100;|        have my doubts :S
SVC_STACK_SIZE = 0x0400;|
MEMORY
  ram : org = 0x20000000, len = 64k <---OK, only this changed
:S, my memory machine specs are:
-----------------------------------------------start
here--------------------
SRAM :
0x080FFFFF 0x08081000 user AP <---- here i must put my app
0x08080FFF 0x08080000 PM      <---- application manager, i must not
touch it
0x0807FFFF 0x08070000 Stack
0x0806FFFF 0x08040000 System buffer
0x0803FFFF 0x08022000 OS
0x08021FFF 0x08000000 System used
FLASH:
0x003FFFFF 0x00210000 User’s AP <---here too, this is the source, in the
other
                                    ocurrence i store the variables i
think.
0x0020FFFF 0x00200000 PM        <---- application manager, i must not
touch it
0x001FFFFF 0x000B0000 Font & Buffer
0x000AFFFF 0x00080000 System F/W
0x0007FFFF 0x00010000 OS
0x0000FFFF 0x00000000 System used
--------------------------------------------------ends
so i dont know what to do, the argument above in:
MEMORY
only specs one memory... i have 2... and one is sram, and other flash...
what must i to do?
Thanks for reading, whatever info is very useful for me please post your
answer, im really afraid about the lost of time :(
Sergio d. Reyes wrote:
> MEMORY
> what must i to do?
include a the 2nd section in the linker script, i.e.
MEMORY
  flash : org = 0xXXXXXXXX, len = 0xXXXXXX
and use the ">flash" at the end of a linker-section (i.e. .text) to
select the memory-section. But you should give some more details. Do you
want your user-application to run from flash or RAM? For "run from
flash" you can use the approach described above. Keep in mind that that
non-zero initial values of variable have to be copied from Flash to RAM
and the address-range which holds the variable which are expected to
init with zero most be filled with zeros (usualy done in the
startup-code). If the user-app should run from RAM (implied by "here i
must put my app") it's a little different since you have to copy the
code from a "persistent" storage (flash) to the memory where it should
be executed (RAM) too. Maybe this is done by a "loader" from your OS,
but wíthout further information it's difficult to help. Anyway, search
for the GNU binutils-manuals and read the linker-manual (ld), it
explains how to place sections at specific LMAs/VMAs.
