Forum: ARM programming with GCC/GNU tools STA2051 Exemple
Author: Ace Kim (vov798)
I am in search for the example about STA2051 CPU.
Share if you have probably a sample example.
thank you.
> thank you.
WinARM is supplied with several examples for ARM7TDMI based devices;
start with one of these and adapt it using information from the parts
data sheet. There are such a large number of ARM devices it is not
reasonable to expect examples to be provided for all of them, and rather
denies one of the advantages of using a common ARM core.
Differences between parts tend to be in the organisation of the memory
map and differences in external peripherals, critical for board bring up
being the interrupt controller, UARTS, and possibly timers (especially
if using an RTOS).
Clifford
It seems that the STA2051 user-manual and detailed datasheet are not
freely available from the STMirco web-site so it's difficult to help. In
addition to Clifford's suggestions I suggest to ask STmirco for the
STA2051 software libraries mentioned on
http://www.st.com/stonline/press/news/year2005/p1713a.htm. Maybe you
have to sign a NDA. Most of the vendors provide examples for one or
several commercial toolsets (Realview, IAR, Green Hills etc.) but it's
an easier start to port existing code made for another toolchain to GNU
binutils, gcc and newlib than to start from scratch.
Author: Spencer Oliver (ntfreak)
> thank you.
The sta20151 (also called vespucci) is just the str710 without the gps
module. It came from the same division.
Rowley have an example with their ide, but any example for the str710
should run on the sta2051.
Regards
Spen
>> thank you.
> Regards
> Spen
I meant to say the str710 with gps.
Cheers
Spen
The rather obvious Google "STR710 gcc" yielded the following:
http://www.yagarto.de/projects/str7usbmsd/index.html
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm...
Clifford
When i mentioned Rowley i meant they have an actual example/header files
for the sta2051.
Cheers
Spen
