Forum: ARM programming with GCC/GNU tools Problem in using STR710 Bootloader
Author: Jam Iqbal (Guest)
Hello,
 I have a question for you. :)
 I am using STR710 Z2T6. The IDE including Compiler and linker, which I
am using is IDEaliST. Whereas the application is for traffic control. It
was working fine. Code was written by some other guy. When I tried to
download the same working code using Bluetooth, It stucked. I guess, it
might be because of I used wrong rom file (and the new code overwritten
bootloader).
 Then I have to make a JTAG interface (Wigggler compatible board by
Anglia). Now after fully erasing the FLASH, when I download the original
s19/bin file of bootloader in flash of STR710, it shows unpredictable
behaviour. After programming FLASH, when I restart the board, after a
couple of minutes (2-3 min), the status LEDs on the board
(GSM,Bluetooth, Heratbeat etc) becomes ON and then the board is stucked.
Even resetting the board, does not turn these status LEDs OFF. Please
remember I have NOT yet downloaded code of my application into FLASH.
This was result of just downloading bootloader in STR710. I changed the
board, but it did not help. Do not know what mistake, I am making. :(
Because the on/off status LEDs of the board should have nothing to do
with the bootloader.
  Just to clarify, setting of my Bootloader rom71x file are:
  CODE (rx) : ORIGIN = 0x40000000, LENGTH = 0x00004000
  DATA (rw) : ORIGIN = 0x20000000, LENGTH = 0x00003000
 Any clue, what to check? Please do not hesitate to ask me if you need
further clarification. I hope your couple of minutes would be helpful to
sort out my stupid mistake. :)
 Kind regards
Jam Iqbal wrote:
Since you have send me an e-mail with the same text I will answer just
in the forum so maybe others can jump in and add remarks.
Which versions of the GNU tools (binutils/gcc) are you using?
> bootloader).
Difficult to help without locking into the bootloader source-code.
> behaviour.
Show the source-code of the bootloader. Are the flash-write routines
executed in RAM? Is remapping handled correctly in the user-application
(location of exception-vectors, remapping bits)?
Are these LEDs connected the the STR7 or to the GSM or bluetooth module?
A lot of GSM and Bluetooth modules offer connections for status-LEDs, so
these LEDs will not indicate problems with the STR7 firmware and just
show the status of the modules.
So the flash-write routines have never been called during the test? Did
you monitor the stack-pointers while the bootloader is active?
Is there some kind of timeout in the bootloader-code so the bootloader
waits for incoming new code for some time and tries to start the
application if nothing has been received?
> I changed the
The LEDs will only give some hints if they are connected directly to the
STR7. Please show the schematic of your board.
It may be just a "stupid mistake" but it's very difficult to sort this
out without the source-code of the bootloader and more information on
the hardware. A minimal example with full source-code for an application
which should be uploaded through the bootloader will help too to see how
remapping is handled, maybe you can extract this from your "traffic
control" application.
Martin Thomas
Newbie writes:
   Thanks a lot for your detailed consideration. I am sorry If I posted
my question with information that is a bit incomplete.  Please find
answers of other questions below:
 - I am using Anglia IDEaliST Version 1.51
 - These LEDs are (indirectly) connected with STR7 through I2C.
 - For questions related to bootloader,I have emailed you my Bootloader
code.
 Once again thanks.
 Kind regards
