Forum: ARM programming with GCC/GNU tools problem with generating hex code
von Abhijeet B. (xmonito)
I'm using arm-elf-gcc on winxp trying to crosscompile and then make
intel hex file for dumping into my target LPC2119 ARM7TDMI. I
successfully compile it and then using objdump create hex file. But the
code isn't running on the processor. I don't know how to use the
target.ld while linking or what i'll have to do to configure it! Please
help! Is there any tutorial where i can find details of
linking,compiling for arm targets?
von Clifford S. (clifford)
There about a million reasons why your code might not run on the target;
most of which have nothing to do with generating hex code. What makes
you think that it is the hex code generation that is the issue? It seems
the least likely explanation. It is impossible to tell from the limited
information given.
That's fair! Actually, i've been using keil compiler,assembler to
generate hex code from C source for the same hardware which works so
hardware is perfectly fine. Cpu is a Lpc2119/01. Keil uVision3 that i'm
using is actually an evaluation copy and now as the code size has gone
past the limitations, i'm upto gcc and i'm a newbie at that. I guess the
compilation must be ok as,
> arm-elf-gcc -c -O2 -mcpu=arm7tdmi filename.c -o filename.o
this generates the filename.o, but if i just link it now without any
crt0.s  into the filename.elf and then objdump to hex, that isn't
working. How can i go about the crt0.s. How can i make it crt0.o. how
can i use it whil linking. or just please help!! Thnks..
Ok! I have got the thing now and its working on the board so thanks!
von alextj (Guest)
This is a really old thread, I'm afraid, but I am in exactly the same
situation - I have LPC2119/01, code compiled with Keil (uVision demo)
works, code compiled with GCC-4.2 toolchain from GNUARM doesn't seem to
work after uploading. It's a bit puzzling, since all the information
about compiling is for Keil, but I can't find anything that would work
with GNUARM.
I guess original poster isn't watching this thread anymore, but maybe
someone can give some ideas/suggestions/links on how to use GNUARM
toolchain?
Thanks
> works,
Using the RV toolset? Or has uVision been used as IDE for a GNU
toolchain?
If you have used the RealView tools (uVision default) you have made some
modifications at least in the startup-code since the RV assembler and
GNU assembler are not compatible. Please show at least your
modficiations.
> with GNUARM.
There are a few examples for LPC2k and GNU tools freely available. Those
from my WinARM page might not be the best ones but should give you some
hints.
von alextj (Guest)
Haha, my the problem was quite simple actually. The test code relied on
a delay function which was optimized out by GCC, which in turn rendered
the whole thing useless. uVision compiler probably had different
optimization settings.
Anyway, thanks for your reply M.T. I'm on my way to making great things
with this MCU ;)
> The test code relied on a delay function which
It is almost always better to use a hardware timer for delay functions,
however, you probably used a loop with a non-volatile control variable.
A good C compiler will see that the control variable is assigned but not
used, and optimise it out - the whole loop disappears. You must expect
this to happen regardless of optimisation settings or compiler, and
simply write the code correctly. If the intent is to create a delay...
volatile int delay ;
for( delay = 0; delay < 100000; delay++ {} ;
The volatile qualifier prevents the compiler optimising out the loop
under any circumstances on any conforming compiler.
Clifford
