Forum: ARM programming with GCC/GNU tools GNU link "Discarded input sections"
von Dustin S. (dbrazeau)
I have a "Discarded input sections" in my map output from linking, and I
believe that there are some functions/variables that are getting put in
this section that I don't want to discarded? How do I keep the linker
from discarding these functions/variables?
Thanks
von Clifford S. (clifford)
The linker will not create output sections which do not have any
contents. So it seems unlikely that the discarded sections contain
function or variables. It would fail to link if any referenced symbols
did not exist.
The standard sections are:
text - for executable code and read-only data
common/bss - for unitialised globals and statics (zeroed at runtime)
data - for initialised writeable data.
If you have variables of code in any other sections it will be because
you have explicitly placed them there with an attribute specification.
And if you did that, the section should presumably not be discarded.
As ever in these cases it is much better if you were to post the actual
output rather than merely describing it. A copy & paste would be easier
for you and more accurate and informative for us.
Clifford
> did not exist.
> Clifford
Here is a small section of the Discarded input sections.
 _ZN2RM7New_WQEEv
                0x00000000        0x0 CfgSer.o
 _ZN2RM4FreeEP7SCmdRec
 _ZN2RM4FreeEP7BuffSeg
 _ZN2RM4FreeEP3WQE
 .text          0x00000000        0x0 CfgSer.o
 .data          0x00000000        0x0 CfgSer.o
 .bss           0x00000000        0x0 CfgSer.o
 .rodata.str1.8
 .text._ZN6CfgSer9SerRecLUNEv
 .text._ZN6CfgSer12SerSixDrivesEv
 .text._ZN6CfgSer8SerRdSbkEv
 .text._ZN6CfgSer3IRdEv
 .text._ZN6CfgSer11SerDumpDoneEv
 .text._ZN6CfgSer8ChkPortsEv
 .text._ZN6CfgSer9SerCUP_CBEP4WQEe
 .text._ZN6CfgSer3IWrEv
 .text._ZN6CfgSer10SerReadRGLEv
 .text._ZN6CfgSer6SerCUPEv
