Forum: ARM programming with GCC/GNU tools Olimex sam7ex256 FreeRTOS problem
Author: Peter C. (peter_c)
Hi all
I'm working now with Olimex Sam7ex256 board.
I've got problem with make file
Others smaller projects work fine but rtos won't compile.
I'm using eclipce 3.3 and win arm 4.1.1
I've got such message:
C:\Program: C:\Program: No such file or directory
make: *** [begin] Error 127
Invalid project path: Duplicate path entries.
but nowhere in the make or project properties or even in PATH there is
no such path.
Where does it come from ??
What should I do to compile that project ??
CC=arm-elf-gcc
OBJCOPY=arm-elf-objcopy
ARCH=arm-elf-ar
CRT0=boot.s
DEBUG=-g
OPTIM=-Os
LDSCRIPT=atmel-rom.ld
# CFLAGS common to both the THUMB and ARM mode builds
CFLAGS= \
-I.  \
-I ./HDLC \
-I./LCD \
-I./SD-MMC \
-I./EMAC  \
-I./Common/include  \
-I./USB  \
-I./lwip-1.2.0/src/include  \
-I./lwip-1.2.0/contrib/port/FreeRTOS/AT91SAM7X  \
-I./Source/include  \
-I./Source/portable/GCC/ARM7_AT91SAM7S  \
-I./lwip-1.2.0/src/include/ipv4 \
-Wall  \
-Wextra  \
-Wstrict-prototypes  \
-Wmissing-prototypes  \
-Wmissing-declarations  \
-Wno-strict-aliasing  \
-D SAM7_GCC  \
-D THUMB_INTERWORK \
-mthumb-interwork \
-mcpu=arm7tdmi  \
-T$(LDSCRIPT) \
$(OPTIM) \
$(DEBUG)
#$(OPTIM)
THUMB_FLAGS=-mthumb
LINKER_FLAGS=-Xlinker -ortosdemo.elf -Xlinker -M -Xlinker
-Map=rtosdemo.map
# Source files that can be built to THUMB mode.
FREERTOS_THUMB_SRC= \
  ./Source/tasks.c \
  ./Source/queue.c \
  ./Source/list.c \
  ./Source/portable/GCC/ARM7_AT91SAM7S/port.c
DEMO_APP_THMUB_SRC= \
  ./Source/portable/MemMang/heap_2.c \
  ./ParTest/ParTest.c \
  ./main.c \
  ./Common/Minimal/BlockQ.c \
  ./Common/Minimal/integer.c \
  ./Common/Minimal/PollQ.c \
  ./Common/Minimal/semtest.c \
  ./BasicWEB.c \
  ./LCD/lcd.c \
  ./Common/Minimal/comtest.c \
  ./serial/serial.c \
  ./HDLC/isdnhdlc.c \
  ./USB/USB-CDC.c
#  ./Common/Minimal/flash.c \
LWIP_THUMB_SRC= \
  lwip-1.2.0/src/core/tcp_out.c \
  lwip-1.2.0/src/core/inet.c \
  lwip-1.2.0/src/core/mem.c \
  lwip-1.2.0/src/core/memp.c \
  lwip-1.2.0/src/core/netif.c \
  lwip-1.2.0/src/core/pbuf.c \
  lwip-1.2.0/src/core/raw.c \
  lwip-1.2.0/src/core/stats.c \
  lwip-1.2.0/src/core/sys.c \
  lwip-1.2.0/src/core/tcp.c \
  lwip-1.2.0/src/core/tcp_in.c \
  lwip-1.2.0/src/core/ipv4/ip.c \
  lwip-1.2.0/src/core/ipv4/ip_addr.c \
  lwip-1.2.0/src/core/ipv4/icmp.c \
  lwip-1.2.0/src/api/tcpip.c \
  lwip-1.2.0/src/api/api_msg.c \
  lwip-1.2.0/src/api/err.c \
  lwip-1.2.0/src/api/api_lib.c \
  lwip-1.2.0/src/netif/etharp.c \
  lwip-1.2.0/contrib/port/FreeRTOS/AT91SAM7X/sys_arch.c \
  lwip-1.2.0/src/netif/ethernetif.c \
  EMAC/SAM7_EMAC.c \
  lwip-1.2.0/src/core/udp.c \
  lwip-1.2.0/src/core/ipv4/ip_frag.c
SD_MMC_SRC= \
  ./SD-MMC/dir.c  \
  ./SD-MMC/disc.c  \
  ./SD-MMC/efs.c  \
  ./SD-MMC/extract.c  \
  ./SD-MMC/fat.c  \
  ./SD-MMC/fs.c  \
  ./SD-MMC/ioman.c  \
  ./SD-MMC/ls.c  \
  ./SD-MMC/partition.c  \
  ./SD-MMC/plibc.c \
  ./SD-MMC/file.c  \
  ./SD-MMC/sd.c \
  ./SD-MMC/time.c \
  ./SD-MMC/at91_spi.c
#  ./SD-MMC/ui.c \
#  ./SD-MMC/mkfs.c  \
#  ./SD-MMC/debug.c  \
#  ./SD-MMC/efsl_dbg_printf_arm.c \
#LCD_ARM_SRC= \
#  LCD/lcd.c
# Source files that must be built to ARM mode.
ARM_SRC= \
  ./Source/portable/GCC/ARM7_AT91SAM7S/portISR.c \
  EMAC/SAM7_EMAC_ISR.c \
  USB/USBIsr.c \
  ./serial/serialISR.c \
  Cstartup_SAM7.c
# Define all object files.
ARM_OBJ = $(ARM_SRC:.c=.o)
FREERTOS_THUMB_OBJ = $(FREERTOS_THUMB_SRC:.c=.o)
DEMO_APP_THMUB_OBJ = $(DEMO_APP_THMUB_SRC:.c=.o)
LWIP_THUMB_OBJ = $(LWIP_THUMB_SRC:.c=.o)
SD_MMC_OBJ = $(SD_MMC_SRC:.c=.o)
#LCD_ARM_OBJ = $(LCD_THUMB_SRC:.c=.o)
rtosdemo.bin : rtosdemo.elf
  $(OBJCOPY) rtosdemo.elf -O binary rtosdemo.bin
rtosdemo.hex : rtosdemo.elf
  $(OBJCOPY) rtosdemo.elf -O ihex rtosdemo.hex
rtosdemo.elf : $(ARM_OBJ) $(DEMO_APP_THMUB_OBJ) $(LWIP_THUMB_OBJ)
$(SD_MMC_OBJ) $(FREERTOS_THUMB_OBJ) $(CRT0) Makefile FreeRTOSConfig.h
  $(CC) $(CFLAGS) $(ARM_OBJ) $(DEMO_APP_THMUB_OBJ) $(LWIP_THUMB_OBJ)
$(SD_MMC_OBJ) $(FREERTOS_THUMB_OBJ) -nostartfiles $(CRT0)
$(LINKER_FLAGS)
#rtosdemo.elf : Cstartup_SAM7.o main.o ./LCD/lcd.o $(SD_MMC_OBJ) $(CRT0)
#  $(CC) $(CFLAGS) Cstartup_SAM7.o main.o ./LCD/lcd.o $(SD_MMC_OBJ)
-nostartfiles  $(CRT0) $(LINKER_FLAGS)
$(DEMO_APP_THMUB_OBJ)  : %.o : %.c $(LDSCRIPT) Makefile FreeRTOSConfig.h
  $(CC) -c $(THUMB_FLAGS) $(CFLAGS) $< -o $@
$(LWIP_THUMB_OBJ)  : %.o : %.c $(LDSCRIPT) Makefile FreeRTOSConfig.h
$(LCD_THUMB_OBJ)  : %.o : %.c $(LDSCRIPT) Makefile FreeRTOSConfig.h
$(FREERTOS_THUMB_OBJ)  : %.o : %.c $(LDSCRIPT) Makefile FreeRTOSConfig.h
$(ARM_OBJ) : %.o : %.c $(LDSCRIPT) Makefile FreeRTOSConfig.h
  $(CC) -c $(CFLAGS) $< -o $@
clean :
  rm -f *.o rtos* Common/Minimal/*.o EMAC/*.o
lwip-1.2.0/contrib/port/FreeRTOS/AT91SAM7X/*.o  lwip-1.2.0/src/netif/*.o
  lwip-1.2.0/src/core/*.o  lwip-1.2.0/src/core/ipv4/*.o
lwip-1.2.0/src/api/*.o ParTest/*.o USB/*.o Source/*.o serial/*.o \
  Source/portable/MemMang/*.o Source/portable/GCC/ARM7_AT91SAM7S/*.o
LCD/*.o SD-MMC/*.o ; touch Makefile
: Locked by Moderator
Peter C. wrote:
> Hi all
> no such path.
First of all check if it compiles from the command-line without Eclipse.
The Problem looks like a file-name/patch issue. I expect C:\Program
should be something like C:\Program Files, maybe you can add quotes
somewhere. If it does not help try to reinstall your tools to a path
with not spaces.
Martin Thomas
> with not spaces.
> Martin Thomas
Well eclipse and winarm are in c:\yagarto\ folder
Projects are in c:\projects folder\
In C:\Program files I do not have any components for IDE, except Java
but that should not be the problem.
You seem to have truncated the build log here - you need to post all of
it. The preceding lines will have indicated what it was trying to
execute that resulted in that error message. Never edit this information
- when you don't know what teh problem is you by definition also don't
know what information is and is not relevant.
And don't manually transcribe it, either redirect it to a file or copy &
paste it from the console window:
http://www.tech-recipes.com/windows_tips249.html
Author: Eduardo P. (Guest)
I am using FreeRTOS v4.0.2 and IAR EWARM V4.42. I'm trying to run the
demo archive from OLIMEX (Board: SAM7EX-256) website.
I changed the IP and MAC address (in uipopt.h) and the code compiles.
Although, nothing happens in the web browser.
Do you have any idea?
Thanks!
You resurrected and hijacked a four year old thread to post an unrelated
question!?  Start a new thread.
This topic is locked and can not be replied to.
