Forum: ARM programming with GCC/GNU tools please take a look in my code
von Thu N. (chutthu)
Hi alls,
I am starting with winarm for LPC2138. After compiling (no error), I run
for testing, but the output is not come. Please take a look on my code
to show where is my error.
#include "LPC21xx.H" // LPC2138 MPU Register
#include "nott.h"
void delay_ms(long int ms)
  long int i, j;
  for(i=0;i<ms;i++)
    for(j=0;j<6553;j++) IO1SET = 0x00;
 void main(void)
  PINSEL2 &= 0xFFFFFF00;  //Port P1.16- P1.23 to be GPIO
  IO1DIR = 0x00FF0000;   //set to be Output
while (1)
 IO1SET = 0x00FF0000L;
 delay_ms(1000);
 IO1CLR = 0x00FF0000L;
 delay_ms(1000);
von Clifford S. (clifford)
The line:
is incorrect. Take a look at section 7.4.3 of
http://www.nxp.com/acrobat/usermanuals/UM10120_1.pdf, especially with
respect to the warning regarding bits 4 and 5.
I believe the following is 'safe'.
PINSEL2 &= 0xFFFFFFF0;  //Port P1.16- P1.36 to be GPIO
IO1DIR = 0x00FF0000;    //set P1.16 - P1.23 to be Output
That's a very crude delay loop given that the part has hardware timers.
The timing of the loop will likely vary between compilers or compiler
optimisation levels and even so is clock rate dependent. The volatile
register access prevents the code from being optimised out altogether,
but it would be more straightforward to simply declare i and j volatile.
Clifford
