Forum: ARM programming with GCC/GNU tools FLash Magic does not seem to work with LPC2119
von Dan Q. (danq)
I am trying to program the LPC2119 using the Flash Magic utility that
comes with WinARM 20070505 and I can't get it to work.  The
communication between the LPC2119 and the PC always fails.  I have tried
numerous option combinations, baud rates, etc. but I cannot get it to
work.
Having said that, using lpc21isp does work.  So I know that the
communication link is correct and there must be something else that is
wrong.
I changed the crystal from 19.6608 MHz to 20.0000 MHz, but as mentioned,
it works well with the lpc21isp, so communication is still fine.
I would like to use the features of Flash Magic (code protect, etc.).
Anyone else having problems with FM or is it just me?
Cheers!
Dan
von Andreas Kaiser (Guest)
Used a LPC2119 at 19,6608MHz with Flash Magic. No problem.
