Forum: ARM programming with GCC/GNU tools declairing volatile struct in include file
von Dustin S. (dbrazeau)
Im trying to:
volatile struct  sDeviceReg
and I'm getting the error:
error: qualifiers can only be specified for objects and functions
Am I doing this wrong??
Thanks
von Clifford S. (clifford)
The error means just what it says, you cab have a volatile variable or
function but not a volatile data type.
struct  sDeviceReg
volatile struct sDeviceReg device_instance ;
or
} device_instance ;
Note that in both cases it is device_instance that is volatile not
sDeviceReg. If you create other instances of this structure, they will
only be volatile if you declare them so individually.
Clifford
