Forum: ARM programming with GCC/GNU tools Setting up minimal C++ run-time environment
Author: Dan Quinz (danq)
I have recently installed WinARM 20070505.  Having compiled some test
code and simulated it with Insight, I am certain that things are working
correctly.
Given the following:
- I do not need the RTTI capability.
- I do not need dynamic memory (malloc,free,new,delete).
- I do not need the stream I/O functionality (fopen,iostream,etc.).
- I will need exception handling.
- I will need to code in ARM 32 bit mode (no thumb code).
My question is: "How can I configure the build/link so that the
FLASH/RAM space used is minimal?"
Currently, even the smallest test program generates a 40k+ image.  With
exceptions handling, it jumps 2k+.
So it seems to me that a lot of code is being linked in that I do not
need and there must be a way to strip it out.
Any suggestions/tips/examples would be greatly appreciated.
Cheers!
Daniel Quinz, P. Eng.
Acacetus Inc.
Author: Andreas Kaiser (Guest)
This is what I use:
Compiler:
-ffunction-sections
-fdata-sections
-fno-builtin
-fno-rtti
-fno-exceptions
-fno-unwind-tables
Linker:
-nostartfiles
Be careful when using things from newlib (e.g. printf).
You need a linker script which takes care of C++ peculiarities, e.g. you
need entries *(.text.*) *(.data.*) *(.bss.*) in the respective sections,
a .ctors section for *(.ctors.*) and *(.ctors) and a dummy .dtors
sections for *(.dtors).
Also the startup initialization should call the C++ constructors.
Andreas Kaiser wrote:
> This is what I use:
> Compiler:
> -ffunction-sections
> -fdata-sections
> -fno-builtin
> -fno-rtti
> -fno-exceptions
> -fno-unwind-tables
Thanks for the tip.  I added all of these except "-fno-exceptions" and
"-fno-unwind-tables" as I need exception handling.  There was no
difference in the FLASH memory, but the RAM usage went down only 8
bytes.
I have found that if I don't define the variable 'device_table_entry'
then I get an unresolved reference error to it during link.  The
functions that reference it are are:
_close_r , _read_r , _write_r , _ioctl_r
All of these are in the 'newlib_lpc' library.
Given that I make do explicit reference anywhere in my code to any of
these functions, nor do I use 'printf', etc., I do not see why these are
being linked
into the application.
I have checked the 'crt0.s' file that I use and there are no references
to these  functions in there either.
There must be a way to avoid linking in these functions if they are not
needed.
Any thoughts?
Dan
> Linker:
> -nostartfiles
Already doing this.
I'm not using either (see above text on newlib linking).
Done. Works fine.
Done. Works fine.
>> This is what I use:
>> Compiler:
>> -ffunction-sections
>> -fdata-sections
>> -fno-builtin
>> -fno-rtti
>> -fno-exceptions
>> -fno-unwind-tables
> bytes.
Make sure to add the linker-option -gc-sections when using
-ffunction-sections and -fdata-sections. If you use the compiler
frontend (arm-elf-gcc) for linking - recommended - add this option:
-Wl,--gc-sections. If you already have some optione passed to the linker
(for exampel already -Wl entry in CFLAGS) just add --gc-sections (I
usualy use: CFLAGS += -Wl,-Map=$(TARGET).map,--cref,--gc-sections)
The newlib-lpc provides the syscalls for the newlib and so indirectly
for the libstdc++.a. newlib-lpc needs the device_table. The use has to
provide it. I'm not sure why you get an error about "device_table_entry"
since this is basicly just a struct defined in dev_ctrl.h.
> being linked
As far as I know the C++ stdlib depends on stdio-functions but I'm not
sure if this can be disabled somehow. A map-file should provide more
information which functions of the library depend on others. The main
reason for the large binary size might be that the C++ stdlib "pulls in"
the complete stdio-support including floating-point (IRC this is around
30kBytes for "plain" newlib without C++).
Maybe the dependencies are "hidden" and from another library like
libstdc++.a.
> needed.
Maybe there is some options like the ones for RTTI but I have not found
it yet. Maybe the Toolchain (esp. the C++ stdlib) has to be rebuild with
special options.
Sorry, a lot of "maybes" and no real solution but hopefully some useful
hints.
Martin Thomas
Check Section "Reducing the Overhead of C++" from
http://www.embedded.com/columns/technicalinsights/201001729
> being linked into the application.
Temporarily remove/rename the newlib. The linker should tell you.
Thanks Martin,
I added the options and recompiled.  The resulting code reduction was
about 4500 bytes.  Little to no effect on the RAM usage (10 bytes), but
I am happier.
I will continue to research a bit more into what the newlib_lpc library
is doing as it seems this is the culprit for the external references.
Cheers!
Dan
Martin Thomas wrote:
>>> This is what I use:
>>> Compiler:
>>> -ffunction-sections
>>> -fdata-sections
>>> -fno-builtin
>>> -fno-rtti
>>> -fno-exceptions
>>> -fno-unwind-tables
>> bytes.
>> being linked
> libstdc++.a.
>> needed.
> special options.
> hints.
> Martin Thomas
Thanks again Martin.
I read this article before and I have added the dummy replacements for
malloc/free/new/delete mad the atexit func.  The net effect is a code
reduction of about 100 bytes, so I'm still not near to removing the
"bottom of the iceberg".
As stated before, I will continue to dig into the libraries to try to
get insight as to what exactly is being linked in and where.
Thanks for your help.
Cheers!
Dan
Thanks to all for your feedback.  I apprecite it!
Cheers!
Dan
Author: Jim Kaz (ancaritha)
The article helped me reduce my code a little bit as well, but I'd also
like to get some more out of it.  Is there anyway to stop it from
pulling in an entire library, or at least make it intelligently use my
function and not include it from the library?  For example
From my map file:
0x534
c:/winarm/bin/../lib/gcc/arm-elf/4.1.2/../../../../arm-elf/lib/thumb/int
erwork\libc.a(lib_a-mallocr.o)
                0x000178a0                _malloc_r
If I attempt to compile the following to override the library function:
extern "C" void *_malloc_r(struct _reent *, size_t) {return (void *)0; }
I get this error:
1>c:/winarm/bin/../lib/gcc/arm-elf/4.1.2/../../../../arm-elf/lib/thumb/i
nterwork\libc.a(lib_a-mallocr.o):
In function `_malloc_r':
1>mallocr.c:(.text+0x0): multiple definition of `_malloc_r'
1>.out/Reduced_Newlib.o:../../../../src/HwDrivers/ARM/Reduced_Newlib.cpp
:31:
first defined here
1>c:/winarm/bin/../lib/gcc/arm-elf/4.1.2/../../../../arm-elf/bin/ld.exe:
Warning: size of symbol `_malloc_r' changed from 4 in
.out/Reduced_Newlib.o to 1332 in
I am not using any sort of malloc, or free or anything of that sort in
my code, and it would be great if it stopped including these
libraries...
Well, I'm not entirely sure what I changed, but while overriding other
functions, I decided to try _malloc_r again to see if I could get it
working at all.  The following works.  Looks similar to what I posted
before huh?  Yea, I dunno?  shrug
After playing around with my code some more, here are some more things
that you can override:
extern "C" void _free_r(struct _reent *, void*) {}
extern "C" void *_realloc_r(struct _reent *, void*, size_t) {return
(void *)0; };
extern "C" void *realloc(void *, size_t) {return (void *)0; };
extern "C" void *_calloc_r(struct _reent *, size_t, size_t) {return
(void *)0; };
These functions should entirely remove malloc.o from your map file and
will drop your flash usage by another couple kilobytes, and should drop
your RAM by about a kilobyte.
Additionally, if you don't use any string manipulation:
extern "C" int _vfprintf_r(struct _reent *, FILE*, const char*, void*)
{return 0;}
That frees up about 14K of flash, maybe 100 bytes of RAM.
I'm looking for a way to remove alloc.o, which means I need to override
__cxa_free_exception and _cxa_allocate_exception, but I'm having
difficulty in finding their declarations.  This will free up a few
hundred bytes of flash and around a K or 2 of RAM.
Thanks for posting that article Martin!  Its been a big help.  I never
knew how to override the functions that got linked in, and this showed
me exactly how to do it.  Thanks!
Something I came across.  The article does __aeabi_atexit, where as I
think we want to use __cxa_atexit, since we are using GCC.  In addition,
we need to use the -fuse-cxa-atexit flag in the compiler.  I have yet to
actually get this to work though, since I keep getting the following
error:
1>.out/HwMemSystem.o: In function
`__static_initialization_and_destruction_0':
1>../../../../src/MemSystem/HwMemSystem.cpp:145: undefined reference to
`__dso_handle'
Additionally, adding the -fno-enforce-eh-specs flag seems like it should
disabled the 'eh_' library includes, which would include eh_alloc, thus
freeing up about 2K of RAM, but it doesn't seem to do that.  The output
file is exactly the same size, sigh.
Hopefully some of my digging will be useful to you Dan.
Thanks Jim!
Your redefinitions for the memory allocation routined helped quite a
bit!  I dropped the flash down by 4228 bytes and the ram by 1040.
There was no effect when I redefined the vprintf function though.
I also experimented with removing the global 'device_table_entry' and
get the following linker errors:
Code:
#if 0
const struct device_table_entry * device_table[] =
  & com1 ,  // stdin
  & com1 ,  // stdout
  & com1 ,  // stderr
  0
#endif
c:/winarm.20070505/bin/../lib/gcc/arm-elf/4.1.2/../../../../arm-elf/lib\
libnewlib-lpc.a(_close_r.o):
In function `_close_r':
C:\WinARM\utils\newlib_lpc_rel5a_src/_close_r.c:71: undefined reference
to `device_table'
libnewlib-lpc.a(_read_r.o):
In function `_read_r':
C:\WinARM\utils\newlib_lpc_rel5a_src/_read_r.c:84: undefined reference
to `device_table'
libnewlib-lpc.a(_write_r.o):
In function `_write_r':
C:\WinARM\utils\newlib_lpc_rel5a_src/_write_r.c:103: undefined reference
to `device_table'
libnewlib-lpc.a(_ioctl_r.o):
In function `_ioctl_r':
C:\WinARM\utils\newlib_lpc_rel5a_src/_ioctl_r.c:75: undefined reference
to `device_table'
So it eppears there is something in one of the libraries that is causing
the stdio stuff to be linked in.  I don't use any of it explicitly, so
it must be coming from the libraries somewhere.
Thanks for sharing your digging.
Cheers!
Dan
> error:
> `__dso_handle'
